If isn't one thing, it's another
To top it off, the POS plastic door handle got caught up, and just my luck the thing cracked in half. Looking on the bright side, it gave me a reason to finally order my RS door panels today. |
Pari,
If you want to come over I can try to help find the prob. I have a circuit safe Snap On test light. If we get time I'll test your leads at Auto therapy on Sat.
The tach has two lights - one each side. Are they both out??
My guess would be that you have swapped one or both of the instrument lights for the high beam warning light and/or one of the turn signal lights. Its easy to do.
Thanks Vu, you got a PM. |
Check the ground. The tach mounts in a rubber ring and I think has a ground wire.
The new tachometer on my 911:
![]() My old one: ![]() As you can see my old one has 3 pins, and my new one has 4 pins. Anyone have a diagram that expains the wiring of SC tachs? Kurt, do you mean there is a ground wire connected under the rubber ring? |
No ground wire in the ring- there needs to be a brown ground wire on the back. There will be a tab on the back that connects directly to the case of the tach.
Give me a call, I'll be wrenching tomorrow. I've got all the electrcial test stuff we need. I also have a spare door handles you can use untill your RS panels come in.
Thanks to Vu-gyver
Here's my tach after Vu did some soldering: ![]() Thanks again Vu. |
| loose rear bulbs & third brake light wiring issue. fixes | red911carrera | Porsche Technical Discussions | 6 | 10-27-2004 05:48 PM |
| Little light in H4's | William Miller | Porsche Technical Discussions | 9 | 10-11-2004 02:26 PM |
| Electrical Gremlin(s) - Must Fix Before Oct 2/3 DE | BlackTalon | Porsche Technical Discussions | 20 | 09-29-2004 10:10 AM |
| Electrical problem ... | rs911t | Porsche Technical Discussions | 9 | 08-12-2004 03:49 PM |
| Electrical test equipment needed.... | VaSteve | Porsche Technical Discussions | 7 | 05-19-2004 10:06 AM |
