ISO a hydraulic pump gasket - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » ISO a hydraulic pump gasket
Old 04-27-2022, 04:43 PM
crg crg is offline
crg
Default ISO a hydraulic pump gasket
i think ive searched to the end of the inter webs looking for a replacement gasket for my 964 hydraulic pump. anyone have any ideas or experience sourcing EPDM gaskets for these?
the pump runs fine, im getting a leak between the motor and the pump.
thanks
craig
1989 C4
Old 04-27-2022, 06:55 PM
I make my own o rings for many things things. Find something close in cross section but larger in diameter. Many cross sections are sold by the foot too.
Cut out a section with a fresh new single edge razor blade to adjust diameter. Make the cuts straight up and down and center out in the circle. Using the end location groove helps if it is accessible. Wipe the new blade with solvent first as any oils will inhibit adhesion. Put a tiny drop of super glue on one end of the o ring then gently and accurately place the ends together. Doing this in a fitted grove helps. Hold for 10 seconds or so then leave it for a min or two. Clean off any excess glue and install in the device. Never ever once had a home made o ring seal fail.
Old 04-28-2022, 08:23 AM
crg crg is offline
crg
thanks Vice..where do you source your rubber by the foot? (there prob a joke there somewhere)
craig
1989 C4
Old 04-28-2022, 10:38 AM
Charlie Stylianos's Avatar
McMaster-Carr sells EPDM orings and cord by the foot.
https://www.mcmaster.com/o-rings/mat...l~epdm-rubber/
Kyriakos E. Stylianos
Baglama inspired
One source https://www.mcmaster.com/materials/thickness~1-32/ just guessed at thickness
Old 04-28-2022, 10:41 AM
ducatithunder's Avatar
ducatithunder
Mcmaster Carr. You can buy oring stock by the foot. Just make sure you get the right material. Are you certain that this oring is EPDM? Buna/Viton is for oil service and EPDM is good for most other applications except oil. Measure the OD and you should be able to get a metric size. They also have the loctite glue for orings ... Loctite 404. Its very similar to superglue. If you can find a local Fastenal you could bring the oil unbroken oring in and get it measured. There is a simple tool to measure the thickness and circumference to get the standard sizing number to order the right premade size. IF you order the stock make sure you think about the durometer rating, not to hard or to soft. Unless you know it i would order middle of the road for hardness. We make orings at work all the time. If done right they are usually bullet proof. Be careful not to have the oring twisted or rolled when glueing it. GL
Current
07 Mini Copper S
99 Dodge Viper ACR
65 Shelby 427 SC
07 Ducati 1098
17 Alfa Giulia Quadrifoglio
Projects
86 "Backdate" 911 2.8 RSR
73 911 T Targa (Sold)
Old 04-28-2022, 11:23 AM
crg crg is offline
crg
thanks folks but the seal isnt an O ring its a flat gasket/seal like you would find on an oil filter. An O ring may work but I'd prefer to use the orginal type.
ref EPDM or SBR rubber- since it is exposed to brake fluid EPDM or SBR is the material that wont break down like viton, buna, and others. Also, i contacted permatex and they dont recommend any of thier gassket makers be exposed to brake fluid.
handy chart for rubber compatibility-
https://mykin.com/rubber-chemical-resistance-chart
craig
1989 C4
Old 04-28-2022, 02:26 PM
ducatithunder
See attached ...
https://www.mcmaster.com/rubber-gask...una-n-o-rings/
you can also order square roll gasket and glue similarly as started before. Mcmaster is going to be your best bet.
Current
07 Mini Copper S
99 Dodge Viper ACR
65 Shelby 427 SC
07 Ducati 1098
Projects
Old 04-28-2022, 04:30 PM
crg crg is offline
crg
Originally Posted by ducatithunder View Post
See attached ...
mcmasters it's going to have to be. i am going to stick with EPDM though, below is from mcmasters website..just a friendly fyi
"Made of Buna-N, these O-rings resist grease, hydraulic oil, and motor oil—plus mild chemicals and water. However, Buna-N is not for use with brake fluid."
craig
1989 C4
Old 04-28-2022, 05:12 PM
Looks like you got your answers! As said you can get o ring material in many cross section profiles. Get some extra and practice a bit.
