I noticed my last two alignments everything stayed pretty close but passenger side rear toe slipped from about -0.2° to -0.14°. Is this anything to have checked?
Bob Peirce [Lara's Dad for those who care] 2016 Audi A7 2021 718 GT4, PDK |
Sounds like maybe one of the adjuster bolts may have slipped a little. Make sure they crank down on the bolts very tight. And, when you get it back from being aligned, look underneath and see if they drew lines from the adjusters to the subframe -- this lets you see quickly if anything has moved. If they didn't, reach under there with a sharpie and mark all 4 rear adjusters (2 each for camber and toe).
Measurement noise. 0.06deg is ~0.5mm across the surface of a 19" wheel. Inconsequential.
Its a good idea to put paint marks on adjuster bolts like Bill mentions but I doubt this is a problem in your case.
OK. That's amazing! I never looked at it that way. That's about 0.02". If this is so small why do people make so much of a thing about rear toe in for stability under braking? I'm running about -0.2deg on 20" wheels. What's that, less than 0.1"?
Rear toe is important. Measuring many points to the left of the decimal not.
0.06 Deg of toe is almost a full millimeter for 20" wheels(see conversion chart in attachment). I prefer to do alignments using millimeter as the unit of measurement since its not wheel diameter dependent and I can grasp the value in my mind better.
When using Degree as the unit of measurement for toe, any value that is less than a whole number is expressed in "minutes". Its unnecessarily complicated, IMO, and for not good reason, also IMO, race car teams only use millimeter or inches. Last edited by TomChan; 04-13-2022 at 06:43 PM. Reason: Added last sentence |
I guess most alignment machines use lasers. I was wondering what the width of the laser bam is, 1-2 mm? Would want to add that to intrinsic error.
- John ‘00 Porsche 996 C2 '72 BMW 2002tii '92 SCCA SSM (sold) '80 SCCA SRF3 (sold) '89 Porsche 944 (sold) '59 Porsche 1600S (long gone) |
I'm beginning to think for rear toe in a pretty broad range is close enough.
A set of strings in the right hands works wonders. The latest blinking lights and color screens can produce junk when not calibrated and used by a tech that does not recognize the issues. A while back a shop sent a number of cars out all cocked up. “but the machine said it was spot on” Good tools in good hands. Besides, toe in modern cars is a bit more than one setting. The other settings have to be right too.
