Spot the problem - Dorkiphus.net
Old 01-24-2022, 12:05 PM
Default Spot the problem
About 2 months ago I had the left front boot replaced. Last night while turning right I heard a loud "bang!" and the clicking noise from the same wheel, like I had cards in the spokes. This was accompanied by additional occasional bangs which increased in both frequency and intensity as I limped away from the spot.
Can you "spot the problem"?
Bonus points if you correctly guess the make and model.
Old 01-24-2022, 03:17 PM
Torqueing the bolts is over-rated...
Old 01-24-2022, 03:20 PM
Dave O's Avatar
Dave O Dave O is offline
Dave O
So is checking the torque after 100 miles. YMMV...
Dave O'Bryan
1977 911 Carrera 3.0 Targa
1987 VW Westfalia w/ 2002 Subaru 2.5 engine at home , 1991 VW Vanagon Hightop camper in Europe, 1987 VW Vanagon Hightop Syncro camper out West, 2014 VW Jetta TDI Sportwagen
Old 01-24-2022, 04:02 PM
Now that you say this, do I see a hole missing a bolt, where a bolt should be? How would this account for the sounds?
Should I have been scheduled for a follow up to check the torque? If so they never informed me or offered an appointment.
Old 01-24-2022, 04:58 PM
They will never have you go back for a torque-check. But in the early days of Dorki, when there was loads of DIY work going on, there were many stories about bolts loosening and how a check after some miles is good insurance.
And yes, at least one bolt is now completely missing. Call the shop that did the work; they owe you a good inspections, and at a minimum a new round of bolts.
Old 01-24-2022, 05:04 PM
Whelp, I had a bad experience getting this done, so I've already taken it to a different shop knowing I might have to pay twice.
Surely this isn't just a round of new bolts and grease? Something got hosed pretty bad here maybe, yes?
Old 01-24-2022, 07:36 PM
Maybe. Could have messed up the screw holes. Hopefully only issue was the screws coming loose, though.
Old 01-24-2022, 09:04 PM
Well my fingers are crossed then! Thanks for the look-see.
I'll post an update once the shop has had a chance to look it over.
Old 01-24-2022, 09:56 PM
slbates's Avatar
slbates slbates is offline
slbates
One of the keeper plates is flopping around the other loose bolt
Steve
996 GT3
996 C2 (gone)
911SC (gone)
Old 01-25-2022, 10:00 AM
mlytle mlytle is offline
mlytle
yup. one bolt was loose and backed out. that was the initial noise. then next bolt loosened enough for the keeper plate to swing out and make the "card in spokes" noise.
should be simple fix.
Marshall
95 M3
97 M3
25 M2
