Top end tools - Dorkiphus.net
Navigation » Dorkiphus.net > Classifieds > Tools Needed/For Loan » Top end tools
Tools Needed/For Loan If you need to borrow some tools, or have tools to loan, post here.
Old 04-20-2004, 11:35 PM
markwemple's Avatar
markwemple
Default Top end tools
Need top end rebuild tools. Once I get it back together, I will need the tools to do the cam timing on my '82 sc. It has the late set up. Also I need one of those ttensioner holders as I am sticking with my OE style tensioners. Thanks!
Old 05-10-2004, 11:11 PM
markwemple's Avatar
markwemple
No Bites? Come on guys, there are a lot of us out here who need them. Any ideas for leads? Also looking for an O/A torch - stubborn head studs!!!
Old 05-10-2004, 11:49 PM
Charlie Stylianos's Avatar
Mark,
I unfortunately don't have any leads on the cam tools. Instaed of using the mechanical tensioners for holding the chains tight, a c-clamp or big vise grips on the idler arms and chain housing work fine. Trick here is to make sure both chains are tight and evenly tensioned.
The trick with removing the stubborn heads studs is to heat the inside of the case where the studs screw in. The factory used some sort of locking compound and the idea is to melt/breakdown that compound. The oxy/mapp setup is fine for this task. It may take a little longer to heat up as the AL. case will quickly transfer the heat, but will work. Keep constant pressure on the stud while heating and it will eventually give.
Kyriakos E. Stylianos
Baglama inspired
Old 05-11-2004, 11:24 AM
Mark
Somewhere out here in Dorki land are my cam nut holder and crow's foot. Hopefully they will turn up and you may use for your project. I also highly recommend the stud extractor tool I purchased for my projects. Only down side is I live out Sterling/Dulles/Herndon way.
Best
Old 05-11-2004, 12:15 PM
William Miller's Avatar
William Miller
Default Tools
Let me know what you need or think you need.
I think I have most of it.
I'm not close.
I see you can do some welding.
I have a rust hole that needs some sheet metal. Is that something you can do?
My guess is it's about 1/2 - 1 hr. for someone who knows what their doing.
Unfortunately I can't move the car. I'll post some pictures of the spot that needs it.
Maybe we can help each other out?
Are you arround this comming weekend?
Thanks! WCM (Bill)
'81 911 SC Red Targa 3.6
'08 335i Blue Sedan
'05 Chevy Tahoe green
'98 Jeep Cherokee XJ "Blue"
'01 Toyota 4 Runner "Pearl"
Darnestown, Maryland
Old 05-11-2004, 07:31 PM
markwemple's Avatar
markwemple
Hi Bill. Yup pretty good with a welder. Not sure if I will be around as I may be a wrench for the 500 this weekend. My mig is portable and I have some spare cold roll galvenize laying around.
I have been trying the mapp/oxy but there are atleast 2 studs that managed to burn through over 2 oxy tanks w/o budging and I had the heat in the right place. I don't know why mine want to be so stubborn but, they do. I really believe I need O/A.
Bill, I think my enginew should be identical to yours. So the tools should match as well. Where is your hole?
Mark
Old 05-12-2004, 08:03 AM
Anonymous Anonymous is offline
Anonymous
The hole is in the front left above the bumper shock bracket. I believe mud get's trapped there behind the washer bottle and the rust worked it's way in.
I posted some pictures in my "project help" post and more ate in the members gallery.
Take a look and let me know what you think.
I bought a few pieces of sheet metal at home depot last night. I did't get galvanized because I recall (Maybe from long ago) that welding galvanized created bad fumes.
Anyway I'm going to start and cut some templates from thick paper. I'm gonna get these to fit before messing with the steel.
I might do this in a few layers. I dont have a break.
Let me know what you think.
Thanks!
I used a arcwelder dozens of time, but not the newer wire welders. Some day I'm gonna buy one. I don't know enough about the different types to make a decision.
Old 05-12-2004, 01:52 PM
William Miller
My brother will be passing by on 50 either tonight or early in the morning like 8am.
Let me know if you can meet him at anglers.
He may be making another trip to and from over the weekend. So if this first shot doesn't work maybe on the way back.
Let me know.
Please give me a short list so I don't forget anything you might need.
Thanks! WCM (Bill)
'08 335i Blue Sedan
Paul Caiazzo has 944/51 specific tools Paul 951 Tools Needed/For Loan 4 12-15-2004 01:25 PM
Holder Trumbo has these tools... Le Cochon Volant Tools Needed/For Loan 3 04-18-2004 03:08 PM
Cam tools for 2.7 motor gjames Tools Needed/For Loan 0 01-03-2004 04:54 PM
PLEASE HELP ... NEED CAMSHAFT REMOVAL TOOLS Doug E Tools Needed/For Loan 3 12-02-2003 11:01 PM
Paul Wilding Porsche tools Justin Fischer Tools Needed/For Loan 1 01-17-2003 08:04 PM
