e39 528i help - Dorkiphus.net
Old 11-20-2020, 11:25 PM
Uncle ENzo's Avatar
Uncle ENzo Uncle ENzo is offline
Uncle ENzo
Default e39 528i help
So I am in the throws of fixing up a 2000 528i 5speed I picked up for 500$. Body and interior were mint so I thought why not? Thus far I have replaced the clutch and rebuilt the vanos and suspension. So when I got the car the brakes were hard as a rock and I discovered the booster didnt hold a lick of vacuum. With that I put in a used working unit. Now comes the issue. When I bench bled the master I got good flow from the rear circuit but not the front two but didnt put too much stock into it. I have a spare master that is just as old that acted the same. I put it all back together and cant for the life of me get the front to spew any fluid at all when trying to bleed. Im thinking I have two worn out masters but wanted to see if you guys had any advice.
Thanks!
Vincent
2009 E350 4Matic
1987 325is
2024 Integra 6spd
2021 CX-9
1998 M Roadster - Sold
2021 Taco - Sold
2009 E91 Touring - Sold
2005 S$ Avant - Sold
2007 Carerra S - Sold
1976 911S - Sold
Acura MDX - Dead
2000 e39 528i/5 - Sold
Old 11-21-2020, 12:07 AM
No fluid when bench bleeding or when in the car? I havent seen one that didnt squirt fluid in the vise. If on the car its possible you have a bench or collapse line. Disco the line from the caliper to check for fluid there, similar upstream if there is a union.
btw, pretty sure a new master is $50, 10% of the car!
Old 11-21-2020, 11:07 AM
Uncle ENzo's Avatar
Uncle ENzo
Actually on the bench. Got very little flow compared to others I’ve done in the past.
Vincent
2009 E350 4Matic
1987 325is
2024 Integra 6spd
2021 CX-9
2021 Taco - Sold
1976 911S - Sold
Acura MDX - Dead
Old 11-21-2020, 10:34 PM
Uncle ENzo's Avatar
Uncle ENzo
At this point I’ve narrowed it down to a clogged valve in the unserviceable abs pump.
Vincent
2009 E350 4Matic
1987 325is
2024 Integra 6spd
2021 CX-9
2021 Taco - Sold
1976 911S - Sold
Acura MDX - Dead
Old 11-23-2020, 09:13 AM
Tito
86911TLCAB
Not sure any help but my 99. 328is has full break system intact. If parts are the Same you can pull off what you need.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 11-23-2020, 10:22 AM
Uncle ENzo's Avatar
Uncle ENzo
Wow, thank you so much. I picked up an ABS pump on eBay last night so ill see if its any good. If not, I am going to reach out!
Vincent
2009 E350 4Matic
1987 325is
2024 Integra 6spd
2021 CX-9
2021 Taco - Sold
1976 911S - Sold
Acura MDX - Dead
Old 11-23-2020, 12:04 PM
Tito
86911TLCAB
Pls let me know soon. Am pushing to get this car out of here soonest. I can pull it off if you think you want it and anything else..
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 11-23-2020, 12:43 PM
Uncle ENzo's Avatar
Uncle ENzo
Thank you! Ill have the used unit by week's end. If you get a sec, take look at the part number on the top of the pump and see if it reads 265.225.005
Vincent
2009 E350 4Matic
1987 325is
2024 Integra 6spd
2021 CX-9
2021 Taco - Sold
1976 911S - Sold
Acura MDX - Dead
Old 11-23-2020, 12:45 PM
Tito
86911TLCAB
Ok. Will let you know.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 11-23-2020, 07:41 PM
Tito
86911TLCAB
It is different
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
