I bought a set of torsion bars 22/30 to go with the 22 sways I have, what else do I need to do an install? The bushings are good but I hate to tear it all down and miss something so I want to have everything ready, I also need a recommendation on a place to get it aligned.
Thanx Thom |
Thom:
There are several shops that can do the alignment but ... seeing as you are south of the B-way try RPM. (Newington). Here is a link to shops in the area. No affiliation, etc... Jason |
You want to do the whole suspension or just the torsion bars? If your car has some miles on it, replacing the ball joints and tie rods might be a good idea too. You know, while you're in there
