Trailer Maintenance Advisory - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Trailer Maintenance Advisory
Old 03-30-2004, 10:32 AM
CrewChief's Avatar
Freeloader
CrewChief
Default Trailer Maintenance Advisory
D
Old 03-30-2004, 11:03 AM
Jim Richards
Good advice on the trailer wheel bearings, John. I used to trailer a sailboat to various regattas and having a wheel bearing fail in the north FL boonies wasn't a whole lotta fun. I learned a good lesson that day.
Old 03-30-2004, 11:10 AM
scott's Avatar
scott scott is offline
scott
I used to have a boat trailer with these things called Bearing Buddies. The dust cap thing with a grease fitting in the center. Pull the boat out of the water and give it two pumps on each axel. Yes, not very enviro friendly as grease just puked out the back. However, it did keep the H2O out of the bearings....Never had to replace the bearing either!
Old 03-30-2004, 06:22 PM
Eric S's Avatar
Eric S Eric S is offline
Eric S
Default Trailers...
John,
I doubt many thought that their rigs included a charging system for the battery - in fact, I'd wager that most have never thought about the battery! An annual recharge would be a very wise precaution!
Also, for those who live in VA, don't forget your annual trailer inspection. I received a ticket on Route 7 near Round Hill last year - and the only reason I was stopped was lack of a trailer inspection sticker.
Old 03-31-2004, 08:52 AM
CrewChief's Avatar
Freeloader
CrewChief
Default Breakaway charging circuit
Eric, the annual inspection is SUPPOSED to include a check of the functioning of the breakaway system. Easy to do.
1) UNPLUG the electrical connection to the tow vehicle to isolate the trailer from the tow vehicle.
2) Pull the 'plug' on the breakaway contact switch. You may, or may not be able to hear the electric brakes pull into the drums.
3) Pull the rig forward gently. The trailer brakes should be full on.
4) Check complete.
It turns out that one can buy a 3 terminal charging unit for the battery for about $15. And I have found self contained units with battery, charger, 'press to test' button, and indicator leds, for $100. The batteries are all the same little rechargeable 12 volt gel cell.
Need trailer parking in/near Arlington Cliff Claven Miscellaneous Discussions 20 08-21-2005 11:13 PM
Trailer Help cmartin Miscellaneous Discussions 18 05-24-2005 12:32 PM
Anyone Have Trailer Space for NASA VIR Event? BlackTalon Track Talk 3 02-12-2004 05:05 PM
A community trailer??? OldTee Porsche Technical Discussions 1 02-01-2004 05:59 PM
