| Tools Needed/For Loan If you need to borrow some tools, or have tools to loan, post here. |
I am going to be replacing the right handside engine cam oil line soon, and I was wondering if anyone has a wrench that will do the job. I see that pelican carries a special 36mm wrench: http://www.pelicanparts.com/catalog/..._%20Wrench.JPG
Does anyone have something that would make this installation work,or should I buy the wrench? |
I have one, your welcome to borrow. I'm in Severna Park, in Reston most mondays.
Lemme know
Have the complete set of 4. You know where I live
I thought the cam oil lines were much smaller. A 15 or 17mm, right?
Good catch Jim! Pari, clarification needed
Pari, The cam lines are something like 13 -14 mm. I have the line wrenches you need. I also have a big A$$ crecent wrench and pipe wrench for the big oil line connections if you ever need them.
Did you buy the cam line restrictors? These simply screw into the top of the cam case wher the oil line connects. A simple upgrade while you are there. I learned that you just order the original part and the new ones should superseed the old part number. My idle oil pressure is now about 2-3 bar depending on temp.
http://www.pelicanparts.com/catalog/...line_right.JPG http://www.dorkiphus.com/porsche/mod...view_photo.php Quote:
Thanks guys, I'll let one of you know when I figure out what tool I will need exactly. Don't I need a 36mm to get this done? |
Pari, just come by. I have what you need.
Cool, thanks Bill. I will probably need a hand with it, since I never replaced these before. I'll give you a call on your cell either this evening or tomorrow.
I'll be home tonight.
| 36mm Oil Line Wrench in Richmond? | kaefer | Tools Needed/For Loan | 1 | 02-15-2005 12:52 PM |
| Need pre-75 fan pulley wrench. | Rick Lee | Tools Needed/For Loan | 9 | 08-25-2004 11:56 AM |
| oil tank line | Parenn911 | Porsche Technical Discussions | 12 | 06-10-2004 08:15 PM |
| In need of a 36mm oil line wrench | vove | Tools Needed/For Loan | 4 | 05-22-2004 05:38 PM |
| What is this metal line attatch to the cross over pipe? | flatsixcrazy | Porsche Technical Discussions | 3 | 05-13-2004 12:50 PM |
