so i burned through a new front set pagid rs29s in 12 sessions
no, i don't think i am braking too much, i guess if i had data from a vbox or aim i could tell, but i don't think i am it could be that i should have replaced the rotors last time too, but i did not i have been trying to find a set of ferodo ds1.11 because you know, they are all the rage right now, all the cool kids are on them! as it turns out, there are none for my car in the country right now, at least not that i can find there might be ship arriving later this week, not that helps me any so, can anyone out here contrast the difference between pfc08's and rs29's ????
RS29 pads have a higher initial bite where the PFC 08 has smoother initial bite. Both work in the same temp range. Both are rotor friendly and have excellent modulation and release characteristics.
The DS1.11 pad needs lots of heat to work properly, if not up to operating temp they're know to chunk material and are hard on rotors. I'd stick with the PFC pad and call it a day. Also, send a pic of the pads you just removed. 12 sessions sounds strange to me.
95 993 16 GTI 02 BMW Spec E46 #27 01 Boxster 86 944- AER/Chump #33 20 F250 Tremor Last edited by Paddy; 07-29-2019 at 04:18 PM. |
Not for nothing, Otto but the cool kids are running DS 3.12s on the front now with the DS 1.11s in the rear. I got a year (forty track days) out of a set of front rotors using the DS 1.11s. Ferodo closes for the month of August so you may not see pads until October if they aren't here now.
Holder 1969 911S 1999 996 C2 Coupe (The Flying Pig) 2016 GT3 Cup 2015 GT3 1988 951 1989 944 S2 2002 Boxster S (project) 1972 914 1.7 2013 Cayenne Diesel (wifey's DD) 2007 E350 4matic wagon DD 2008 Chevy 3500 dually tow truck |
i don't think ds3.12 are available for my 981 stock i thought about ds1.11 front and dsuno rear, kind of like rs29 front rs14 rear with pagid ds3.12 front and ds1.11 rear would be worth a try for certain, if i can get it but would this be an issue with bridgestone re71r tires? the brake guy indicated i might want to wait until i get fitted with nitto nt01's i also need to keep in mind that i drive my car, on the tires, too and from the track, so keeping with dot tires ferodo recommends not using ds3.12 pads on the street whereas ds1.11 and dsuno are ok for street
The difference between NT01s and RE71s is not a whole lot. The NTs have a bit more grip and durability. (But not a lot of tread for driving to and fro).
i once drove back from mid ohio on completely smooth nt01 tires, in the rain, down hill slip and slide, lol the re71r have impressed me in the rain, but they are fresh, who knows what they will do as they age
I run 1.11 all around in the 981 and I'm very happy with that pad. The balance is good and the modulation is fantastic. I get a year out of rotors on that car and roughly 5-6 days on the front pads.
I run a 3.12 on the front of the Corvette and a 1.11 in the rear and I'm happy with the balance in that car now. The Corvette always needed a touch less pad in the rear for me or I'd get some lockup in the rear. The 3.12 is a great pad and it lasts longer with comparable rotor life in the C7 to the 1.11. The 1.11 was a bit better in modulation (preference), but with the extra speed, heat, and weight of the C7, the 3.12 is necessary. The 3.12 is still easy to modulate, but it feels different at full tilt and I had to get used to the pedal pressure change at the start of releasing the brakes. The lighter pedal modulation closer to apex is very similar between the two.
2019 Corvette Z07 - Urf-Qke #777 2016 Corvette Z07 - LightSpeed #707 2014 Cayman S - Sparkles #81 2005 Corvette jackstand racecar |
i just ordered a set of ds1.11 for the 981 the last shipment is stuck in customs so i don't know when i will get them, maybe tomorrow, maybe next week they don't make the ds3.12 for the 981 yet ken at https://knsbrakes.com runs a vette also, and shared a similar story yes, i am plugging KNS brakes
I guess this’ll be considered stirring the pot a little, even though that’s not my intent - but every time I see a thread like this I wonder what everyone is talking about. I put over 1800psi through the pedal of my SPB with clean traces, and can even run with Hunt on my best days (kinda). Yet I have no idea what everyone is talking about when it comes to modulation, release characteristics, and feel. I just mash the pedal as hard as I can for the shortest possible time. What am I missing?
Btw I run Pagid blacks. They last 5 days.
1999 SPB v2 2001 911 track/race car 2016 Cayenne GTS 2021 Ford Explorer Gone: 2006 Cayman S 2006 911 S SPB v1 |
