991 Service - Dorkiphus.net
Old 05-23-2019, 07:01 PM
Jabs1542's Avatar
Jabs1542 Jabs1542 is offline
Jabs1542
Default 991 Service
Is anyone, non-dealerships, repairing 991’s yet? I mean real repair not replace till the problem goes away.
I just had a Coolant System Failure Indicator on my MFD. Last time this happened it was a COV (Change Over Valve), the car has 7 of these and when any fail the first indicator is the Coolant System. The previous repair was under CPO so I have no idea how much this will cost (though I will soon find out) - they replaced 3 COVs at that time.
I have taken the car to Porsche of Tyson’s for an estimate. What I am looking for in this thread are alternatives, not sure if any of the indies have made it to the fault isolation and detection level on the 991 platform. And is anyone doing this at home in their garage? The COVs are relatively cheap (less than $20 each) and are a very common problem with this car, has anyone has figured out how to isolate these for replacement?
Jay
2013 C2S
Racecars are like strippers, we just keep throwing money at them hoping someday they give us the ride of our lives…
Old 05-23-2019, 07:10 PM
#polishforprez
I would consider calling Jose Herceg at Autobahn. He typically knows the newer cars pretty well.
- 2020 quickly disappearing...
Old 05-23-2019, 08:22 PM
jhsmith's Avatar
jhsmith jhsmith is offline
jhsmith
Charlie at Intersport...
Jim
White '91 SSM Miata #01
Yellow '19 718 Boxster (Wife's)
Black '15 GMC Yukon XL w/ '98 Trailex (Tow Vehicle)
Orange/Brown-ish '75 FJ40 (in case I run out of other car projects)
Old 05-23-2019, 08:46 PM
No reason why you cant DIY, if you want to. I've read about this but havent touched one. Seems pretty common and some just replace them all 'because they are cheap'. Not so analytical. You could test each solenoid with 12v but I'd rather get the actual values from a durametric or similar. Sorry I dont have first hand experience, just reading up.
Old 05-31-2019, 04:52 PM
kimlangley8 kimlangley8 is offline
kimlangley8
Rennlist has some posts on this issue :
https://rennlist.com/forums/991/8002...-on-991-a.html
as a new 991.1 driver I'm trying to get up to speed quick in all this new technology as my other 911 is a 80 SC..
is this the component you are talking about??
Kim Langley
1980 911 SC
2012 Carrera [991.1]
1973 BMW 2002Tii
2004 BMW 330Ci
Old 05-31-2019, 05:14 PM
Hurricane's Avatar
Hurricane Hurricane is offline
Hurricane
That’s a good thread - I posted in it last year lol. COV issues are such a pain in the 991.1. The GTS (or S w/power kit) has 10 COVs compared to the 8 in the base or S, even more to fail!
I had a 2012.5 991.1 S and the COVs were changed with a “campaign” in 2013. I still had two COV related failures after that, in 2014 and 2015 (I owned the car from 2014-2016). The heater failed and then later the PSE (Porsche Sports Exhaust). Once those COVs were fixed, I never had a problem again.
I also had a 2013 991.1 S with powerkit (owned for a a little over a year, 2016-2017) that never had any problems. I think that once you get the latest version of the COVs changed, they seem pretty reliable after that.
Thankfully, I have not heard of any COV issues on the 991.2s.
"Bill"
2018 911 GTS Sapphire Blue
2013 Carrera S (991) w/Powerkit, Aerokit Cup, PCCB, PDCC w/SPASM (Gone to Porsche Heaven...)
2012.5 Carrera S (991) (Sold)
2006 Corvette Coupe (Sold)
2000 Corvette Coupe (Sold)
Old 06-02-2019, 08:29 PM
Jabs1542's Avatar
Jabs1542
Yes, this is the part. You may also see that I was on that Rennlist thread. The trick is; a) figuring out which COV is bad, b) locating it, and c) replacing it.
I ended up with 2 dead COVs that got replaced for a little over $500, that was the easy part. The really bad news was the vacuum pump, that cost another $1000.
Vacuum pump you ask? This is due to the Coast and Auto Start modes. Apparently they had to add an external pump so that a proper vacuum could be maintained when the engine is shut down. Progress...
Jay
2013 C2S
Old 06-03-2019, 08:36 AM
Dandelion's Avatar
Dandelion
It could be worse...
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 06-03-2019, 12:38 PM
edevinney's Avatar
Most Courteous Driver
edevinney
Wow. It could.
Purcellville
993 + Boxster S + Eurovan MV + 4Runner
Old 06-04-2019, 01:43 PM
Call me Scooter
I saw 2 991's on Chapman's lifts a few weeks ago. Chapman auto works sterling.
http://agent.allstate.com/SBresnahan/Welcome
88 911 E stock
2005 Cayenne
