Fuel leak in a fo fo - Dorkiphus.net
Old 05-16-2019, 10:34 AM
John Hallen's Avatar
John Hallen John Hallen is offline
John Hallen
Default Fuel leak in a fo fo
Asking for a friend who recently acquired a 944, which had been sitting for a long time. It's got a leak in the fuel line by the gas tank. I suggested rather than just patch, giving the age and unknown condition to replace the whole line. What sort of an ordeal is he looking at? Any tips, suggestions I can pass along would be greatly appreciated.
John Hallen
69 911T Targa
01 Harley FXST
01 E46 325CI
05 Kubota BX2230
Old 05-16-2019, 12:32 PM
The pump, filter and some shortish hoses are back there, possibly under a cover. IIRC, they attach between the tank and the metal line that runs the length of the car. I would check the parts in the back first. Wouldn't surprising to find some leaking at hose clamps on now dry, shrunk, and hard tubing. Replacing all the lines might be overkill.
Old 05-16-2019, 12:34 PM
Very true. The cost of the replacement lines would exceed the value of the car!
Old 05-16-2019, 02:39 PM
racer's Avatar
racer racer is offline
racer
be sure to check the fuel rail in the engine compartment.. no point fixing the back and then. bam.. gas leaks on a hot engine!
Give your friend this link : https://www.clarks-garage.com/
Dave
- 1970 914-6
- 2000 Boxster
- 1987 944
- 1987 924S
- 1978 911 Euro SC
- 1976 914 2.0
- 1970 914 1.7 / 2056cc
Old 05-16-2019, 08:06 PM
John Hallen
Thanks so much guys. Though I can muddle my way through the mechanics of an early 911, totally clueless as to a 944. Was thinking maybe Porsche threw in a fuel line like it did with the 80's Carrera that had a disagreeable habit of disintegrating and causing a car-b-que.
John Hallen
69 911T Targa
01 Harley FXST
01 E46 325CI
05 Kubota BX2230
Old 05-16-2019, 08:21 PM
X2 on checking clamps and hoses first. Fuel rail is also known issue.
Old 05-20-2019, 11:48 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
You didn't say what year it is and it makes a difference as the early cars have metal tanks and the later cars (85 1/2 up) have plastic ones and the lines hook up differently to the fuel pump. I have 2 early parts cars currently behind my garage with non leaking tanks and parts if he needs something. The lines can be a pain to get off if they are corroded since ummmmm heating rusted stuff back there can be ummmmm life threatening. I have had to cut some off and replace the end fittings. BAT (and others) make these nifty metric compression fittings that will replace just the end of the fuel line if need be so you can just replace the old stuff with new stuff.
89 944 Turbo Race car
98 993 C2S w/Aerokit II
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
Old 05-21-2019, 05:37 AM
BeerBurner's Avatar
BeerBurner BeerBurner is offline
Glorified babysitter
BeerBurner
I had to replace a rubber line or two back there some years ago (I don't remember the specifics) on my '87 because of a fuel leak. It wasn't really hard or expensive to do.
BB.
Some say "My car is a Porsche!" I say "My Porsche is a car!" and I drive the hell out of it.
'87 Porsche 944; '10 BMW 328i xDrive (her's); '98 BMW 323is (ours)
Old 05-21-2019, 06:20 AM
jsheiry's Avatar
jsheiry jsheiry is offline
jsheiry
Depending on the year/type 944, 944S, 944S2.... this guy makes custom kits to replace all fuel line rubber. As most of these cars are 30 years old his kits make a lot of sense to spend a little time and replace all the little hose bits. Link at Pelican http://forums.pelicanparts.com/porsc...-line-kit.html
John
92 968 Maritime Blau (few bullet holes...rescue in progress)
94 968 Polar Silver Cab (prepping for sale)
95 968 GP White Wifes DD
93 968 Amazon Green Cab
94 968 Iris Blau Cab
92 968 Lagoon Green
94 968 Polar Silver M030
87 944 NA track/de car
72 Signal Orange 914 survivor
Old 05-21-2019, 03:03 PM
dnwong's Avatar
dnwong dnwong is offline
dnwong
Hmm... glad you guys brought up this issue. I have been smelling gasoline every time I go into the garage. Looks like my 944T must have a gas leak too. Like to know which hoses ended up replacing.
Dudley
Aldie, VA
99 996 C4 Black/Black Areo
86 951 Graphite / Burgundy
2002 BMW 530i
2008 Volvo XC90
1995 Chev Astro (workhorse going-bald)
My Garage Build
