| View Poll Results: Which action cam would you buy today for the track? | |||
| GoPro Hero 7 Black |
1 | 25.00% |
| GoPro Hero 7 Silver |
0 | 0% |
| GoPro Hero 7 White |
0 | 0% |
| GoPro Hero 6 Black |
1 | 25.00% |
| GoPro Hero 5 Black |
0 | 0% |
| Garmin Virb Ultra 30 |
1 | 25.00% |
| Garmin Virb X or XE |
0 | 0% |
| Other (please post) |
1 | 25.00% |
| Voters: 4. You may not vote on this poll | |||
I've been using Harry's LapTimer with generally good results, but I'm getting fed up with the video problems caused by the well-known iPhone poor stabilization effects for on-track video recording. So, I'm considering biting the bullet and buying an action cam. I've looked at the action cams page on Harry's website, and it's a good starting point, but I'd like to ask the crowd here their thoughts. I want a camera that (1) will be good for years to come, (2) will work easily with HLT, probably meaning can be auto started by HLT, and (3) will work with other solutions down the road if I later decide to invest in a more sophisticated track timing/data solution. The obvious choices are GoPro Hero 7 (Black, Silver, or White), Hero 6 Black, Hero 5 Black, and Garmin Virb X/XE/Ultra 30, but welcome any/all suggestions.
Thanks, Jordan
1999 Spec Boxster 2018 Audi Q7 |
I have used both GoPro and Garmin cameras for flying and the track. Picture quality is about equal but the big difference is the Garmin has built in sensors and will pull data from an OBD-II reader wirelessly. The battery lasts longer and their video editing program is easy to use and gives you tons of options on the types of gauges you want to include. My avatar was a still pulled from a GoPro video before I purchased the Garmin XE. The GoPro mounts are better so I use them with my Garmin.
Mike 14 981 Cayman S Wall of Dearly Departed Loved Ones 07 987 Cayman S 03 996 86 944 74 914 78 924 Bro Code Rule 43: When a Bro learns another Bro has been in a traffic accident, they must first ask what condition the car is in. |
I’ve been down this path using Track Attack because HLT didn’t support external cameras and OBD readers at the time. Here’s what I learned:
1) Get a GoPro that has WiFi (required) and the touchscreen on the back (highly recommended), also get the skeleton case to keep it cool. Be careful to setup your GoPro carefully as it will create a WiFi network that your cell phone will need to connect to. 2) You will want to provide power to the GoPro (it will consume 2+ batteries in a day). This means you will need to rig a 12:5 volt adaptor to a switched power source and run wires. 3) You should also look at an OBD reader, it will connect to the phone through BlueTooth. 4) You should also look at an external GPS,it will also connect through BlueTooth and will be MUCH more accurate than your phone. Now the warnings: a) Getting all of this to work is a PITA and doesn’t always work correctly.I had a big off at VIR that didn’t get captured because of this. You will need to start your sessions extra early in order to get this symphony of components to work. b) I will be presenting a data class (White Classroom) showing the differences between ‘hobby data’ (a.k.a. cell phones) and serious data (i.e. VBox and Aim). I will cover processing speed and frame rates, and how you can use each tool effectively (tip, there is a HUGE accuracy versus precision issue going on here). enjoy
Jay 2013 C2S Racecars are like strippers, we just keep throwing money at them hoping someday they give us the ride of our lives… |
For comparison, this is what I'm getting from HLT using an iPhone 4S for front video and an iPhone 7 for rear video: https://youtu.be/bFnAMbgXb-8
So as most know i would suggest biting the bullet earlier so you get more use out if it.
However, ive used a multitude of gopro's Hero7 battery is definately less record time than the older ones. A simple usb power source us an easy addition which takes care of that. File size is also key.....the bigger the files the longer the processing times when reviewing 1080 is plenty....4k is rediculous....but you may loose youtube funding without 4k hah. I have an old hero3 silver that actually worked very well with HLT... Once you realize the amount if time spent processing data to review....vs processing what you need to work on.....start the budget asap and dont look back Evan
Evan 87 911 E stock GONE.......: 84 911 Estock 2015 E stock national champion Close Motorsports - Driver Coaching and Data Equipment sales Website coming soon Old http://retaliatemotorsports.blogspot.com/ Last edited by Der ABT; 05-12-2019 at 04:45 PM. |
If you're looking to do this for the goal of driver improvement, I would prioritize something that gets you closer towards squiggly lines and think about leaving HLT in the past. I know budget is a factor, but the ability you have to quickly use that data to make changes between sessions goes up tremendously.
2019 Corvette Z07 - Urf-Qke #777 2016 Corvette Z07 - LightSpeed #707 2014 Cayman S - Sparkles #81 2005 Corvette jackstand racecar |
data point on the Go Pro's..
-hero 6 and newer have built in GPS and accelerometer. with about three clicks in the gopro editing software you can overlay a track map, speedo and g-force circle. super simple. here is basic example i did at MC track day. the size of all the data on screen is user adjustable. https://youtu.be/YATggN7D7aE and a short one from a HPDE on Jefferson when i was following an intermediate student. key to car video is that it needs to show what the driver is doing. cell phone or camera on dash or roof does not allow analysis of driver actions/inputs.
Marshall ---------------- 95 M3 97 M3 25 M2 Last edited by mlytle; 05-13-2019 at 12:57 PM. |
I'll be trying out the Waylens Horizon camera this weekend. I've had it for a couple years but never tried it on track. It might be a good stopgap between a Gopro and dedicated data loggers.
Aaron 1993 964 2004 GT3 2017 M3 |
