Reusable Vinyl Race Numbers - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » Reusable Vinyl Race Numbers
Old 06-28-2018, 09:57 AM
RV4Flyer's Avatar
RV4Flyer RV4Flyer is offline
RV4Flyer
Default Reusable Vinyl Race Numbers
Has anyone ever tried using the reusable vinyl for your race numbers? If so how did they hold up? They are a little pricey and wondering if it is worth the investment. My car lives outside in my heavily regulated HOA community so I cannot keep regular vinyl numbers on full time and painters tape looks like crap plus it leaves a film on the car when removed. I had magnetic numbers which worked well the past few seasons but the newer Cayman has aluminum doors.
Mike
14 981 Cayman S
Wall of Dearly Departed Loved Ones
07 987 Cayman S
03 996
86 944
74 914
78 924
Bro Code Rule 43:
When a Bro learns another Bro has been in a traffic accident, they must first ask what condition the car is in.
Old 06-28-2018, 08:33 PM
Too Tall Too Tall is offline
Too Tall
http://www.soloperformance.com/Autoc...bers_c_34.html
Just scored numbers from solo performance. They might work? Certainly good for Autocross.
Josh Simonds
07' 997.1 Atlas Black
"this ain't tennis, I suggest you figure it out if you plan on doing this sport"
Old 06-29-2018, 07:17 AM
nylart nylart is offline
nylart
I've been using the vinyl numbers from http://gochecker.com. They look very good, but are a bit pricey. If you can keep the back of them clean, they should last a couple of seasons.
Art
Old 06-29-2018, 10:46 AM
Toby's Avatar
Toby Toby is offline
Toby
Yes removable vinyl worked well for me for many years. (I bought big sheets from soloperformance and cut numbers/letters myself.)
Much more secure than magnet (can't believe those are even allow on track...) and easy to peel off and stick back to backing sheet when the event is over. They hold up very well.
Toby
2005 997
www.teamshum.com
Previous:
2009 Boxster S
1991 964 C2
2001 Boxster S
Old 06-29-2018, 11:34 AM
RV4Flyer's Avatar
RV4Flyer
Art
Art, which did you go with? The static cling or satin low tack reusable?
Mike
14 981 Cayman S
07 987 Cayman S
03 996
86 944
74 914
78 924
Bro Code Rule 43:
Old 06-29-2018, 12:19 PM
997C2S 997C2S is offline
997C2S
I've got the static cling ones from GoChecker... they're great... Ive got at least 5 years out of them and still going strong. Car started as a dedicated track car and is now a SpecE46 race car. I leave them on all the time...occasionally used to pull them off if I need to change the numbers for any reason (different clubs, etc)... They adhere well. The trick is to keep the backs clean, and apply to a surface that does NOT have heavy wax or detailer. Wiping the spot where you plan to apply them with a damp rag and dish soap works well
Tim S.
997C2S
& a whole mess of BMTroubleU
Old 06-29-2018, 04:47 PM
DaveInMD's Avatar
DaveInMD DaveInMD is offline
DaveInMD
I've been using the reusable vinyl from Solo performance for several years. The real trick is to remove carefully so you don't deform the vinyl and to keep the tacky surface clean.
Dave
2006 Cayman S, #25
2014 Cayenne Platinum Diesel
2012 VW GTI
Old 06-30-2018, 10:20 AM
nylart
I used the static cling from Gochecker. Since I take them off after every event,it can be difficult to keep the back pristinely clean. Once there is dirt on the back, they don't stick all that well.
Art
Old 07-01-2018, 04:24 PM
Handlebar's Avatar
Handlebar Handlebar is offline
Handlebar
I used to use the removable ones from Solo. They could handle about one full season.
I went with a Cricut cutter (miscellaneous craft cutting, teacher stuff, and decorative crap I don’t care about), with the feature of cutting my own removable vinyl numbers for ridiculously cheap. If I go with digital bars for numbers, I can get 4 sets of numbers made for $2-3. Simple to use. All my numbers for last two years have been home cut.
1988 911 Carrera 3.2
(1995 911 - gone)
1997 Spec Boxster - #121 (gone)
2004 911 GT3
2022 Mini Cooper S
2017 F250
