Cold weather project question. - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Cold weather project question.
Old 01-30-2004, 03:33 PM
GB83SC's Avatar
GB83SC GB83SC is offline
GB83SC
Default Cold weather project question.
I finally received all the parts needed to change the color of my interior from tan to black. The question is the cold garage space?
Ist:
I am going to remove all the interior and spray my tan headliner with a vinyl color spray.
2nd: going to replace the tan carpet with a new carpet kit from original fit interiors.
The spray can for the color spray and the 3M carpet adhesive recommends temp's above 60 degrees.
I want to start on this project tomorrow morning, is this ok to try with a small heater in the garage or wait for the warmer weather?
Thanks.
George B.
Old 01-30-2004, 03:55 PM
Jim Richards
George, I dyed the interior vinyl and changed the carpeting on Lu's 73E last winter. You'll need a heater to make your garage temp stay above 50 degrees. Of course the fumes will make the weekend go by in a blur.
Old 01-30-2004, 04:03 PM
jpnovak jpnovak is offline
jpnovak
You could probably get by with the lower temps but it will take forever. The glue will not dry at low temps. >50 deg is needed for the solvents to evaporate.
Jamie
Old 01-30-2004, 04:38 PM
APKhaos's Avatar
APKhaos APKhaos is offline
APKhaos
Off you go to Home Depot!
Buy yourself a small propane heater, which will keep your garage above 50 for the job. BTW, you need to keep it above 50 for the whole drying period. Would not reccommend leaving the propane heater on overnight, so maybe your small electric will be enough to hold the temp.
Tony K
PCA Potomac, Rennlist Member
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 01-30-2004, 04:40 PM
Karl S's Avatar
Karl S Karl S is offline
Karl S
One suggestion. Go to a construction equipment rental place and rent one of those big kerosene-fire heaters they use on construction projects. They sort of look like a mini jet engine on wheels. Get 5 gals. of kerosene and you'll be able to keep the garage at a toasty 72 degrees all day long, no matter what the outside temp is. Just imagine working in a tee shirt at this time of year
Old 01-30-2004, 06:21 PM
estrellajon's Avatar
estrellajon estrellajon is offline
estrellajon
George, Karl just reminded me of a kerosene heater I have in my basement storage you can borrow. I have lots of kerosene as well. I know you just love my propane heater in my garage. But the Kerosene will do great.
Karl, I thought you were going to the race?
Jon Estrella
Werk 1 Euro 930S
K27-7200, Kokeln IC @ 1 bar boost., B&B front mount oil cooler, B&B headers and exhaust.
Old 01-30-2004, 07:05 PM
GB83SC's Avatar
GB83SC
I guess its a green light on this project
I have had the car for almost four years and wanted to change out the color from day one.
Thanks for all the help guys!
Jon, I will take you up on the heater.
George B.
Old 01-30-2004, 11:27 PM
If you are using anything with flammable solvents then heater and enclosed space = Boom!
Better read the contents of the materials used before you start. The solvent based contact cements used for automotive carpets are very flammable and will also get you high as a kite if used in an enclosed space. The water based contact cements work but not as well.
If the solvents are water based then you can use a kerosene, electric or propane heater. The above mentioned propane will run you $40 to purchase from Home Depot. This is less that the rental of a powered heater. Somewhat less heat but it will warm up a good sized room. Just stick it on a 20# propane can. I have one and they work great. (I would lend you mine but it is in used this weekend) The powered rental heaters are noisy as hell but put out a LOT of heat and can heat you right out of a regular sized garage in about 10 min but you will be warm! If you don't have a large space to heat then one of the propane heaters might do the trick and you can use it on the tank off the back yard grill. No oil stink no extra fuel cans and it is small and easy to store when it is not on the tank.
Old 01-31-2004, 11:35 AM
Karl S's Avatar
Karl S
You mean Daytona? No, I thought about it but since I'm headed down to Sebring for the Club race in two weeks, I decided that two trips to FL that close together was too much. I'll be watching today on Speed however. TPC is on the pole in their class for the 24 hour race.
Old 01-31-2004, 10:30 PM
estrellajon
Karl, I saw they were on the pole. Is Mike driving that car? Will your car be ready as promised?
Jon Estrella
Werk 1 Euro 930S
Newbie Question Regarding Bleeding Brakes TD in DC Porsche Technical Discussions 21 05-26-2005 07:54 AM
Mid-Ohio Shift Point Question TD in DC Track Talk 15 04-26-2005 10:47 AM
My 2.4E --> 2.7RS DiY engine project Jim Richards Porsche Technical Discussions 84 01-13-2005 12:44 PM
A question on 911S tdatk Porsche Technical Discussions 12 07-08-2004 08:59 AM
Potomac Question HPDC Question Doug E Track Talk 43 09-30-2003 07:36 PM
