FS: Bulldog Trailer Tongue Jack A-frame Topwind 2000lb - Dorkiphus.net
Navigation » Dorkiphus.net > Classifieds > Other Stuff For Sale » FS: Bulldog Trailer Tongue Jack A-frame Topwind 2000lb
Old 09-16-2017, 04:46 PM
elmodius elmodius is offline
elmodius
Default FS: Bulldog Trailer Tongue Jack A-frame Topwind 2000lb SOLD
This was installed on our car trailer when we bought it, but was only used a few times because we replaced it with a motorized jack. So it is like new as far as the mechanism, but the red handle is faded a bit from the sun. $17.50 - local pickup only.
BULLDOG round jacks are recognized as the industry standard by leading agricultural, commercial, horse, livestock, and other trailer manufacturers. For more than three quarters of a century, BULLDOG jacks have been demonstrated to be the most reliable, field-proven jacks on the market.
Smooth, comfortable, ergonomic design
Dependable vertical and side load capacity
Proven reliability for long term use at rated loads
Precision fitted parts for extra stability
Zinc outer and inner tube
Specifications:
Lift Capacity: 2,000 lbs.
Retracted Bracket Height: 8.40"
Extended Bracket Height: 23.40"
Travel/Lift: 15"
Clearance: 13" from bracket to top
Weld-on/bolt-on bracket works with any standard A-Frame mount
Handle Radius: 6.65"
Inner tube diameter: 2"
Outer tube diameter: 2-1/4"
