My '86 944 N/A has 30mm torsion bars, Konis and 425lb. springs in the front. I currently have a 24mm swaybar in the front and 17 in the rear. Car is really only driven on track unless I drive it the 45 minutes to SP from home, but not really worried about street ride quality. Looking to make it handle better on track....is going to 968 m030 bars too much or the way to go?
_______________________________________________ Tim M '00 C5 Corvette FRC track car '86 944 N/A (aka Doublemint) - Past '20 Ford Expedition Max |
What about the car's handling are you trying to fix?
I'm trying to "finish" this car. Trying to make it handle the best it can, rather than a car I have now that is not street but also not as capable on track as it can be. So to answer your question, I would say less body roll, however I'm also painfully aware of my lack of suspension IQ and don't want to slap parts on resulting in a car that becomes a nightmare to drive.
M030. You've already got stiff springs, may as well go with stiff bars too
At a minimum, M030 stuff... I'd go even stiffer in the front....
Dan '03 Mini Cooper S Cone Dodger |
I have a M030 bar laying around if you're looking for one.
95 993 16 GTI 02 BMW Spec E46 #27 01 Boxster 86 944- AER/Chump #33 20 F250 Tremor |
PM sent.
There are a lot of compliant suspension bushings you may want to replace as well as add stiffer bars, stiffer springs. Changing the bushings lets you "feel" things a little easier as well.
If I were going to the trouble of trying to stiffen the rear I would remove the torsion bars and go with a coil over setup as its much MUCH easier for novices to set up, change, change again. Indexing torsion bars although technically not that difficult, practically speaking they are a TON of work. As they say "it aint hard work, its just nothin but work" The M030 968's have thicker/stiffer torsion bars as well as an add on "helper" coil spring setup on top of the shock. As interesting as this approach is its cheaper to go in other directions like the complete coil over and torsion bar removal. If your going to ultimately class race your 44 then also check your class about torsion bar removal as some dont allow it. Here is a link to some interesting info on these transaxle cars from the guys at Racers Edge. They are talking about a 968 but 99% of the conversion is good and applies to your 44. http://www.racersedge-inc.com/racers...0?open&id=10.1
John 92 968 Maritime Blau (few bullet holes...rescue in progress) 94 968 Polar Silver Cab (prepping for sale) 95 968 GP White Wifes DD Past 93 968 Amazon Green Cab 94 968 Iris Blau Cab 92 968 Lagoon Green 94 968 Polar Silver M030 87 944 NA track/de car 72 Signal Orange 914 survivor |
