Has anyone re-carpeted their 911? I was planing on changing the carpet but need some advice or help on the process.
Jon Estrella Werk 1 Euro 930S K27-7200, Kokeln IC @ 1 bar boost., B&B front mount oil cooler, B&B headers and exhaust. |
I'd be interested in learning this process as well. Most of my carpet is in good condition, but I would like to replace the portion near the door sills.
Can you buy just certain areas or do you have to buy a whole kit?
BTW, I finally got around to putting in my stereo. I did a temporary job and hooked up the front speaker outs to the stock wiring thing for the factory fader. (Crutchfiled gave me a nice harness and my hands were freezing so I had to stop). So it's a little underpowered - but way nicer than the 20 year old Monterey. Do I have to disassemble the shift console to get to the wires for the back speakers?
As for the rear speakers, it would be just as easy to run new speaker wires to the rear. The plus side is you upgrade the wire vs using the stock wire and bypass that fader.
Jon, Why would you ever want to replace the carpeting, strip it instead so that the 930 will be lightweight, while you're in there you cant take out the back seats too.
Steve, glad to hear that you finally got the cd player in there. What about the car phone ? |
I have done a few and can walk you through the process
Pari, that would be nice to make it lightweight but what's another 5 lbs.
Kurt, I may need your experience to tackle this project. Any recommendation or FYI's before I start this?
Use contact cement to install carpet. There are now 2 kinds to use one stinks and will get you high if you sniff too much while using it but works great and the other is latex based and works OK if you use it correctly.
if you have never installed carpet in a car I recommend that you do this project with someone that has, There are a bunch of little tricks that will make the project easy and come out better. There is little room for "oops" cuts and the like. 911 carpet is installed in a set order. Each section overlays some of the last section and covers the raw edges. Take the seats front and back out. Take all the trim off. Strip the old carpet off, noting the order of installation. Keep all the fasteners with each item removed. Clean up all glue surfaces and vacuum the area of all loose debris. Installation takes some skill to get it right. The glue prepped carpet sticks on contact and cannot be moved without much labor and posable damage to the section being installed. The vinyl strips on the ends of some of the sections need to be carefully placed and coaxed into place. Get a bunch of single edge razor blades. Don't even think of cutting with anything else as you will get runs and pulls. Use each blade for 3 or 4 cuts and discard. I buy them in the 100 box. There is more than this to installing auto carpet. It is not hard to do but it it is easy to mess up if you want to or go at it unprepared. Feel free to call me if you have ?
I replaced the 73E's carpeting last winter...closed garage, lots of fumes...that probably explains a lot about me.
| Need help changing brake rotors | rs911t | Porsche Technical Discussions | 25 | 03-21-2005 05:43 AM |
| Getting glue off after pulling the carpets | Eli | Porsche Technical Discussions | 27 | 01-19-2005 05:11 PM |
| Changing valve springs | cmartin | Porsche Technical Discussions | 15 | 11-11-2004 12:24 AM |
| Where to buy a carpet set? | William Miller | Porsche Technical Discussions | 8 | 05-03-2004 11:53 AM |
| Anybody ever dye carpet? | William Miller | Porsche Technical Discussions | 0 | 10-02-2003 12:11 PM |
