Switching from vintage registration to regular - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » Switching from vintage registration to regular
Old 09-24-2016, 01:43 PM
88carrera's Avatar
88carrera 88carrera is offline
88carrera
Default Switching from vintage registration to regular
Hi everyone,
This vintage registration is for the birds. I drove the car to work this morning and I got pulled over by a police man. He asked me was I on my way to display the car and I told him no I'm just going to work. Apparently that's illegal with vintage plates and he cited me.
If I switch back to regular registration would I need to have the car Maryland inspected?
Howard
2003 996TT
1993 Mini Cooper
(SOLD) 1974 Datsun 260z, 1997 911, 1988 911
Old 09-24-2016, 03:09 PM
Casey914's Avatar
Casey914 Casey914 is offline
Casey914 has two HoF threadsCasey914 has two HoF threads
Those are the guidelines in VA as well. I am going to get my landcruiser up and going and then swap to traditional registration.
Old 09-24-2016, 03:45 PM
alw20147's Avatar
alw20147 alw20147 is offline
alw20147
In VA you can get vintage tags with for "general transportation purposes" which allows for daily use. When tagged for general transportation purposes, the vehicle must comply with all the safety and registration requirements.
Al W.
2001 911 cab
Old 09-24-2016, 04:34 PM
Quick930 Quick930 is offline
Quick930
Originally Posted by 88carrera View Post
Hi everyone,
Yes you will need to have it MSI and you will also have to have emissions done every two years.
Old 09-24-2016, 05:11 PM
edevinney's Avatar
Most Courteous Driver
edevinney
"going to work" will get you in trouble in both MD and VA. However, old cars don't sit very well, so a long drive to get good and hot and blow out the cobwebs is essential.
Don't know if this would fly in MD but I have strong secondhand info that it can work in VA. Bonus: it's true.
Old 09-26-2016, 01:03 PM
IIRC, there was an allowance for using a Historic tagged car for commuting if your regular DD was in the shop. Or if you were otherwise taking the Historic car to a shop, maybe you could it drive it work first. But I guess proving the point could also be your undoing. I've heard about someone else getting ticketed for commuting, but because the cop saw them do it repeatedly.
But getting ticketed for driving it once is absurd. What if its a nice day, and you wanted to drive your historic drop-top instead of the minivan? IMHO, it may be worth fighting the ticket, just to make the point that occasionally driving should be allowed.
Not sure if converting back requires a new Inspection, but would put the car back into the VEIP rotation.
Old 09-26-2016, 01:23 PM
Hi everyone,
All you needed to tell him was you were dropping it off a shop on the way home. That's also on the what's allowed list.
We still have regular tags on the '71 and 356 but antique on the race car. In VA after 25 years you don't need emissions with regular tags. Just safety inspection which is pretty easy. Wanted to be able to "road test" race car w/o the yearly inspection is the only reason it has antique. Both 964s qualify now too. One was sold but I plan on keeping regular tags on L's track 964 for now.
Old 09-26-2016, 01:45 PM
Cliff Claven Cliff Claven is offline
Cliff Claven
i can’t answer your question, but if this was a one-time thing, then i’d argue the ticket.
From MD DMV:
A vehicle registered as historic cannot be used for general daily transportation, or primarily for the transportation of passengers or property on highways. It can only be used in exhibitions, club activities, parades, tours, occasional transportation and similar uses.
this means it is OK to drive it occasionally for transportation, but not as a general daily commuter vehicle.
you could explain to the judge that it was a one-time thing and that you need to run the car occasionally to keep it mechanically sound and operating. then show the judge information about your other vehicles. you can show evidence of the mileage you put on each of your vehicles, showing that significant miles are accruing on your other vehicles while minimal miles are accruing on this vehicle, thus demonstrating you are not using this one for daily transportation.
now, there were some changes to the law this year in Maryland, adding a new restriction that creates a bright-line rule against ever driving your vehicle as a transport to and from work. but that new restriction does not take effect until oct 1. when you were ticketed, the old law was in effect. if the old law had prohibited occasional use of the vehicle to drive to and from work, then the amendment would not have been necessary.
your cop jumped the gun on issuing the ticket, and totally screwed you. was probably unintentional, maybe he missed the part of the memo explaining when the new law kicked in.
bottom line: fight it. but don’t do it anymore.
Old 09-26-2016, 01:50 PM
Goldie's Avatar
Goldie Goldie is offline
Goldie
^this^
88 carrera....If you received a ticket from an officer from the City of Rockville, I might be able to give you a hand/pointer for that matter.
2012 X5d | Grey | His
2011 335d | Blue | Hers
1994 Miata | Black | Teaching Toy
Old 09-26-2016, 02:20 PM
Originally Posted by Cliff Claven View Post
.......now, there were some changes to the law this year in Maryland, adding a new restriction that creates a bright-line rule against ever driving your vehicle as a transport to and from work. .....
Not saying you should lie about it....but IF you were actually going to drop off the car at a shop after work, or you had picked it up from the shop before work, is that still prohibited under the new law? If so, that seems a bit egregious.....even for Maryland.
