Troubles with Transaxles in Silver Spring (944 N/A) - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Troubles with Transaxles in Silver Spring (944 N/A)
Old 04-13-2016, 02:46 PM
CrookedRacer CrookedRacer is offline
CrookedRacer
Question Troubles with Transaxles in Silver Spring (944 N/A)
Hello everyone, welcome to my first post. It's a plea for help.
If you're near Silver Spring and wouldn't mind lending your ears to a problem I'm having with my '88 944 NA track toy, I'd appreciate it.
I've documented the issue in a couple posts on Rennlist.com. First I started a thread when I thought I knew what the issue was:
http://rennlist.com/forums/924-931-9...88-944-na.html
Then I asked for help more pointedly:
http://rennlist.com/forums/924-931-9...e-flanges.html
Finally, I'm hoping there is someone more local that can actually listen to the car with me. I'm in Hillandale (just outside the beltway off New Hampshire Ave).
Tonight I'll be doing some recordings and running the car on stands to try to locate the noise better. And I'll be working on the car on Saturday morning as well.
Here's my build thread on the car, for even more background:
https://grassrootsmotorsports.com/fo.../105890/page1/
PM me and let me know if you have an ear for 944 problems and, if so, what kind of beer you like.
Old 04-13-2016, 03:32 PM
blipshift's Avatar
blipshift
I had a rhythmic noise (more of a womp womp womp than a crisp click) coming from my 944 when I owned the Red Baron. Similarly the noise was most pronounced under acceleration. Took some investigating but the root cause was a bad wheel bearing. YMMV. http://dorkiphus.net/porsche/showthr...edownandlocked
Harry
Current
2019 C7 GS
2018 Armada Platinum
2005 Silverado
1984 944
2005 Larson Cabrio 31
2018 Keystone 3220
Gone
2014 Mk7 GTI
2005 997
2003 350Z
1986 951
1986 MR2
1985 944 (Red Baron)
Old 04-13-2016, 04:55 PM
CrookedRacer
Thanks!
I don't think it's the bearings, since I just replaced them both:
I hope they haven't already starved themselves of grease...
Old 04-13-2016, 08:47 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
Take them out and turn them around one at a time and test drive. This allows them to turn in the opposite direction and if one of the cages is galled or stretched it will sometimes quit making the noise since the ball bearings are now pushing on the opposite side. The driver side usually goes bad first due to the heat from the muffler. Doing them one at a time will help narrow the cause.
Steve Potomac PCA Co-CI
89 944 Turbo - 2010 944 SuperCup Mid-Atlantic Champ, 2013 944 SuperCup North Chapter Champ
85.5 944 NA son's 2015/2019 944Cup and PCA Nat'l Champ racecar
98 993 C2S w/Aerokit II
77 911S project
70 Boss 302
86 Mustang SVO
08 F250 SD Diesel
15 Audi SQ5
Old 04-14-2016, 12:46 PM
CrookedRacer
You're talking about the CV joints, right?
I swapped axles which effectively does what you're describing. Same EXACT noise. If it were the CV joints making the noise, I'm sure swapping the axles would have affected the noise somewhat.
The TICK TICK TICK sound is a lot more frequent than once per revolution of the wheel. It's like 6 or 8 times the wheel revolutions. As if there's some piece of metal that's striking the cheesehead bolt heads of the CV's as they go by, like the little indicator flap on a wheel of fortune.
Old 04-14-2016, 12:52 PM
Tito
86911TLCAB
I have a similar sound on my e36...very low and only seems to be there during colder mornings...after driving a bit or during warmer mornings I don't hear anything...does the sound you have go away or remain after a few minutes of driving?
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 04-14-2016, 02:15 PM
CrookedRacer
Thanks.
It's actually quieter for the first few hundred yards or so. Then it becomes plenty loud and distinctive for the rest of the test.
When I first heard it, I was ten miles from home. It only got worse.
Old 04-14-2016, 02:16 PM
blipshift's Avatar
blipshift
Only happens when in gear and under acceleration, yes? Does the noise stop when you put the car in neutral and coast?
Harry
Current
2019 C7 GS
2005 Silverado
1984 944
2018 Keystone 3220
Gone
2014 Mk7 GTI
2005 997
2003 350Z
1986 951
1986 MR2
Old 04-14-2016, 06:04 PM
CrookedRacer
Yes, it stops when coasting. In neutral, or in gear. All I have to do is lift on the accelerator pedal to quiet it completely.
Touch the accelerator again, and it's suddenly loud again.
Old 04-15-2016, 11:49 AM
Tito
86911TLCAB
could it be an exhaust sound?
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
