987 new clutch around 60k miles? - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » 987 new clutch around 60k miles?
Old 09-12-2015, 04:38 PM
88carrera's Avatar
88carrera 88carrera is offline
88carrera
Default 987 new clutch around 60k miles?
I know this depends on how the p.o. drove the car but would a clutch be nearing replacement after 60,000 miles?
I also read that I should pull plug #2 and #5 and inspect for burning oil. If evident that may indicate cylinder wall scoring?
Howard
2003 996TT
1993 Mini Cooper
(SOLD) 1974 Datsun 260z, 1997 911, 1988 911
Old 09-13-2015, 08:18 PM
edevinney's Avatar
Most Courteous Driver
edevinney
My 911 needed a clutch when I got it at 34k, and once inside it was clear that this was the 2nd one. So, yes, entirely possible based on driver.
Old 09-14-2015, 12:19 PM
With respect to the second question, yes pull plugs to see if they are oily. If they are borescope it.
Look for :
The most popular cylinders seem to be #2, #4, and #6. One of the symptoms will be a tapping sound when cold dissappearing when warm in the early stages. No visible smoke because the cat is eating it, although there is a little swing from the rear o2's..
In the later stages intermittant tapping cold or warm. Now we have visible smoke. The rear o2's are swinging because the cat(s) are done.
Either stage the engine is done. Have seen 4 since January.
Old 09-14-2015, 01:48 PM
great info, thanks Matt
Old 09-14-2015, 03:23 PM
spiffyjiff's Avatar
spiffyjiff
great, i have tapping.
Chris M.
Old 09-14-2015, 06:20 PM
88carrera's Avatar
88carrera
Matt do the 9A1 engines have this issue?
Howard
2003 996TT
1993 Mini Cooper
Old 09-14-2015, 06:39 PM
It seems that this is happening on 2002 onwards to the brand new moderls of non-metzger engines.
Old 09-14-2015, 07:43 PM
Especially 3.6s
Old 09-20-2015, 10:25 AM
turkis_tii's Avatar
turkis_tii turkis_tii is offline
turkis_tii
In looking to buy a pre-owned car, I assume a PPI would pick up on this?
Old 09-20-2015, 06:49 PM
You may have to stipulate the PPI includes pulling the plugs and if oily doing more. Quality of PPIs aren't equal and seldom mean the same thing to all people. Comes down to the shop and how much you want to spend.
