05 525i rough idle - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > BMW Technical Discussions » 05 525i rough idle
Old 10-29-2014, 08:44 AM
pookie's Avatar
pookie pookie is offline
pookie
Default 05 525i rough idle
Guys,
Still helping a buddy with his car. It has been having a rough idle for some time. While driving everything is fine, but at idle upon startup it gets lumpy (for lack of a better term). Also, when pulling into a parking spot, prior to shifting into park, or even while in park, it also gets lumpy and almost hunts for the right idle speed. Last time he brought it over I was able to track down what I thought was a slight air leak at the crank case valve breather hose. He replaced the hose and the idle smoothed out for awhile but after a month is now back to the regular lump.
I don't know enough about these cars, so I am posting here. I'm hoping you guys can tell me what else it might be. A sensor of some sort maybe?
Thanks
1976 911S Targa 3.2 swap
Old 10-29-2014, 09:38 AM
Interested as well. One of the reasons I was asking about a service place besides the valve noise is a hunting idle.
Old 10-31-2014, 11:13 AM
Tito
86911TLCAB
Ryan, did you pull the idle control valve and clean it up? looks just like the one on your 3.2...pull it and use some carb cleaner to clean it out real good as well as the associated hoses...could be clogged and not moving freely.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 10-31-2014, 12:57 PM
jerome951
How many miles on the car? On my '06 330i, a new set of plugs cured a lumpy idle @ 60k miles.
Jerome Welte
'97 Spec Boxster
'20 Nissan Titan XD
'02 BMW 330i convertible
Old 11-02-2014, 11:11 AM
Vacuum leak. Like Lupus it's one of the last things that considered.
Old 11-03-2014, 12:52 PM
pookie's Avatar
pookie
TR- we checked for vacuum leaks and that's how we found the breather hose.
Jerome- Current mileage is 125k and the plugs were done around 5k ago. (Could the plugs be gapped incorrectly and causing it? He did the plugs on his own.)
Tito- no idea on the ICV. I will look up its location and check it when he brings the car over.
Old 11-03-2014, 06:29 PM
Intubator's Avatar
Intubator Intubator is offline
Intubator
Bad coolant Temp sensor??
Chris Robel
1987 Carrera Targa 3.4 993SS cams, Smokey Silver Semi-Daily Driver
2006 Cayman S, Guards Red, #11 part time track addict (sometimes #12 or #22)
X-Terra, Blue
1970 911 T coupe, Bali Blue
1982 911 SC Targa, Guards Red
1974 914 2.0, Champagne Gold
1982 BMW 528e, White and rusty..
Deceased but not forgotten:
1968 911 sunroof coupe, Black
1972 VW Super Beetle, White
Old 11-05-2014, 05:58 PM
Clarke's Avatar
Clarke Clarke is offline
Clarke
I'm going to assume that since you didn't mention it, there is no CEL on, or codes stored. At this mileage, I would be checking the DISA valve to make sure that it is intact. You should also be looking at the CCVV and it's associated hoses. The oil return hose (goes from the bottom of the CCVV to the dip stick tube. Also check the intake boots. If the idle issue is more obvious when ambient temps are low, it could be VANOS seals.
Clarke
'79 SC Euro
'93 BMW 325is
'54 Chevy 210
