Picked up a 964/993 car that ran GT1R. I replaced the turbo with a 3.6 964 engine ( cup flywheel / chip ) 2556 pounds. would it run in GT3?
thanks
GT1R GT4 14-6 GT5 Bug GT3 GTi |
I'm not sure, but let me take it out at Summit Point this weekend, and I'll tell you what I think
Sounds like a blast at 2556 lbs!
Seems pretty simple to figure out. Classes GT-1 through GT-6 GT cars will be classified by calculating a “performance index.” The performance index applies the same principle of classification as used for the stock classes, which is weight/horsepower. The formula is: Performance Index [PI] = (Weight/[Displacement [D] x Horsepower/Liter for engine type] [T]) x 100 Transposing terms when you know your engine and the class you want to run in gives this: Minimum weight for your car in your class = (minimum class PI x D x T) /100. There are 16 engine types. Displacement in the formula is the exact displacement of the engine to the nearest thousandth of a liter. The weight in the formula includes car, driver and driver gear. The table below provides the HP/L for your engine type to calculate the Performance Index or minimum class weight for your car: Engine Type (T) HP/L 4 cyl air cooled 90 4 cyl air cooled turbo 150 6 cyl air cooled 110 6 cyl air cooled turbo 210 4 cyl 2 valve water cooled 100 4 cyl 2 valve water cooled turbo 185 4 cyl 4 valve water cooled 115 4 cyl 4 valve water cooled turbo 230 6 cyl 986-based (M96 engine, any chassis) 135 6 cyl 987-based (M97 engine, any chassis) 140 6 cyl GT3 with single throttle 165 6 cyl GT3 with six throttle bodies 175 6 cyl water cooled turbo (any chassis) 240 8 cyl 2 valve 90 8 cyl 2 valve turbo 145 8 cyl 4 valve 100 8 cyl 4 valve turbo 165 Classification is as follows: Performance Index (PI) Class 425 and below GT-1 426 to 550 GT-2 551 to 675 GT-3 676 to 825 GT-4 826 to 975 GT-5 976 and above GT-6 • It is permissible to add ballast to change one class only. Ballast is defined as removable weight bolted into the car solely to achieve a target weight. Ballast may be placed anywhere in the car so long as it is appropriately and adequately secured. • Cars not on DOT or equivalent approved tires must add an additional 50 pounds to their formula based minimum class weight. • GT class, engine displacement, engine type and minimum weight must be written in the car’s log book on the inside cover. 2014
Scott Bresnahan Purcellville Va. 2014 GTB1 World Champion 8 Time National DE champion 88 911 Cup 2021 GT4 13 Boxster S 1969 Saab Sonett 2013 Cayenne 2014 F150 Hurricane race trailer with A/C 05 Cup car 02 Koni 996 |
Depending on the power to weight ration, PCA 3S or 4S. There a plenty of 3.6 powered cars in 4S. Dyno it, weigh it, and go from there.
Mark Francis OG Racing: Proud Sponsor of the Potomac Region DE Program OG Racing SPB #91 93 964 C2, Polar Silver 89 944 S2, Baltic Blue 89 944 2.7 Guards Red (son's) 86 944, International Harvester Red (Oswald) |
No more S and R any more. Tires are free. One GT class now.
Dyno it?
