My Wife's 1978 VW 1303 Restoration - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Other Technical Discussions » My Wife's 1978 VW 1303 Restoration
Old 01-06-2014, 08:24 PM
rothaus's Avatar
rothaus rothaus is offline
Hall of Fame My Wife's 1978 VW 1303 Restoration
It's not a P-car, however, I like to share what I'm doing.
Here we go:
I have started the restore of my wife's '78 VW 1303 Cabrio.
I like to share the progress and hope to find some information during the process.
I found the beetle and did some repair 13 years ago and it was a birthday present for my wife. Now after these years we have some issues with rust, top, etc.
Here is what it looked 13 years ago.
It took me a while to actually start on it, but now it's real.
Now in the works, started actually last winter.
Some progress in between other stuff.
Here we go - no comments needed:
Disassembly of the top.
Outer skin is off
Got some rotten wood
All is gone
Next, the sound mats, with heater gun and scraper
Doors off, they have some rust at the bottom, details later.
Engine is also out, a little easier as the 911.
The dash is gone, the wire harness from the fuse box to the rear end as well, and the windshield.
Removed the rest of the wire harness.
Disassembled the doors etc.
Here some pictures
What happen to this car ????
Why does it have a hole, and it looks like somebody cut it out with a chainsaw.
Anyway, I think I need to fix this, besides other holes.
Here is one door. It has some rust at the bottom.
Door Hardware Art
More progress on the beetle, besides other stuff.
Drained and removed the gas tank.
Next, the front suspension
Is now also gone.
Now I need to make some braces for the upper part of the body, where the doors were. And then split to body from the chassis.
Installed the braces
Separating the chassis and the upper part
Transmission removed
Rear suspension removed
Got some new pieces
To be continued
Cheers
Engelbert
2015 911 Turbo
2012 Boxster S
2006 Cayenne S
1982 911 SC
1978 1303 Kaefer Cabrio
1971 911 3.6
Old 01-06-2014, 08:45 PM
Awesome write up. I bet you giggle with happiness when you see prices for VW resto parts after working on Porsche for so long.
Old 01-06-2014, 09:18 PM
The rough hole in the dash is probably from dealer-installed A/C. There would have been a big fugly aftermarket blower/evap assembly in the front trunk, just behind the dashboard.
FYI this guy has a good selection of convertible top parts, like replacement wooden bow for your rotted one: http://www.chucksconvertibleparts.com/
Old 01-06-2014, 10:26 PM
Wow, you don't do anything partway do you?
Looking cool!
Old 01-06-2014, 10:30 PM
antonioconceicao's Avatar
antonioconceicao
Very good sir! If you need a place for plating parts the shop I am using at Ohio does a great job.
Nice!
2007 997 Turbo
1990 G Wagon Diesel
1990 Porsche 964 C2 G
1985 Citroen CX GTI
1988 Citroen BX GTI
1976 Vespa GTR 125cc
1970 Citroen Mehari
1968 Citroen ID 20
1965 356 C
Old 01-06-2014, 11:03 PM
Awesome! Keep 'em coming
Old 01-07-2014, 09:41 AM
Love it!
Old 01-08-2014, 09:38 PM
rothaus's Avatar
OK, more about the beetle:
Old Floor pans removed
Cleaning up the old welds
Test fitting the new boards, just fitted with sheet metal screws
They actually did fit really good, even they are made in Brazil... LOL
Fitting the schuh
Getting closer
Looks like the schuh fits
Even the holes line up
Back apart and finish welded
Applying seam sealer and primer
And the final coat at the bottom.
Did some cleaning/blasting of small part for the rear suspension, etc. prepping for powder coat.
The chassis is done, also at the top, and ready for assembly.
Did some power coating. The stove works OK, however, I need to watch the temperature. Some improvement is needed for the temperature control.
Bending and installing some brake lines
Put the rear suspension back together
New bushings
Powder coated spring plates and covers
Now with the control arms
Moving back the to body, since I waiting for some suspension parts.
New front piece installed with the left and right bumper support section
Attacking the rear part of the wheel well, which looked like an easy task.
Not so... more under the skin
Reconstructing all the pieces
Welding it back in
More stuff to fabricate
The skin, finally
All welded in and cleaned up. The next piece is the brace of the strut tower.
More coming soon.
Cheers
Engelbert
2015 911 Turbo
2012 Boxster S
2006 Cayenne S
1982 911 SC
1971 911 3.6
Old 01-09-2014, 07:14 AM
Great project, and write-up! Its amazing how much corrosion you've found for what appears to have been an otherwise nicely maintained car. Its a lot of work, but the end result will be amazing.
For a truly "over the top" finish, perhaps you should consider this item on eBay, with bids still being accepted.
http://www.ebay.com/itm/ws/eBayISAPI.dll?ViewItem&item=171207023079
Old 01-09-2014, 07:34 AM
realroadrage's Avatar
Trust.....but verify
realroadrage
Best thread on Dorkiphus in a while. Awesome stuff!
Everything has changed
