Split CV Boots? - Dorkiphus.net
Old 10-01-2013, 12:53 PM
PorscheBound PorscheBound is offline
PorscheBound
Default Split CV Boots?
Did a search and did not come up with anything. I need to replace a torn CV boot on my 01 Boxster S. Does anyone know of any company that sells split CV boots?
Old 10-01-2013, 01:18 PM
BobNovas's Avatar
BobNovas BobNovas is offline
BobNovas
LOL! Good luck with that...
Replacing your CV boots is a FUN job. I take it to my mechanic. YMMV
Old 10-01-2013, 01:21 PM
Complete remain axles are ~$100, not that bad. Good how to here, http://www.pelicanparts.com/techarti...nt_-_Boots.htm
I think you will find the consensus is DO NOT use a split boot. Pull the axle and replace the boot with a one-piece boot.
Old 10-01-2013, 01:52 PM
Roo's Avatar
Roo Roo is offline
Roo
X2
CT
83 911SC
12 Lexus CT 200h
08 Outback wagon
04 F250 SD
Truth be it known, I just like working on cars - Slick Henderson
Old 10-01-2013, 02:21 PM
Potomac-Greg's Avatar
Potomac-Greg
Yup. I can't imagine a split boot can be very reliable. And if it splits open, your CV joint is done in a matter of a day or so. And then you'll get a new CV and a one-piece boot!
Greg
Rockville MD
Old 10-01-2013, 05:16 PM
Split boots (if they even make them for a Boxster, and I doubt it) are a temporary band-aid, not a fix.
Old 10-01-2013, 05:22 PM
PorscheBound
I found on the 986forums that some people have used split boots with no problems. With that said, no one can seem to give me an answer as to where they got them from. I work at a shop so doing the work myself is no problem. Looks like I will just have to end up getting a non split boot. Oh well.
Old 10-01-2013, 05:27 PM
Don't. Use. A. Split. Boot.
If you work at a shop, why would you risk you car by doing a marginal fix? In fact, if you get the shop discount, might be much more worth it to replace with a full built axle. Value your time...
Old 10-01-2013, 05:29 PM
PorscheBound
I run with the whole if its not broken don't fix it motto. My car is never driven in bad weather and might get 6k miles a year so a split CV boot does not scare me too much unless it was a DD.
