FIOS internets issue - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » FIOS internets issue
Old 08-04-2013, 09:04 PM
SilverStreak's Avatar
SilverStreak
Default FIOS internets issue
Since there are a few computer types on this board I thought I might run this by you.
I just got FIOS (finally) and I've got an issue. The wireless function just stops working every few hours. It's like it has a timeout function or something. I have to reboot the router a few times a day. The ethernet connected stuff all works just fine. It's just the wireless. I'll be surfing away for a few hours and then it will just quit.
It's not device specific either. It stops allowing internet access for my Tivo, Windows LT, MacBook, Nooks and ipads. Everything.
This is the second router at this point.
Any ideas?
Hunt
611racing.com
OG Racing Team
Vimeo
1999 SPB #611
2004 Wrangler
Old 08-04-2013, 09:16 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
We have Verizon DSL and have the exact same problem and so do several people I have talked to. Several calls to customer service have not solved the issue yet. They suck. Looking into Comcast cable modems now.
89 944 Turbo Race car
98 993 C2S w/Aerokit II
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
Old 08-04-2013, 09:31 PM
SilverStreak
I see a place to turn off the wireless radio. CAn I just connect my old Cisco router and use that instead?
Hunt
611racing.com
OG Racing Team
Vimeo
1999 SPB #611
2004 Wrangler
Old 08-04-2013, 10:08 PM
tbernard's Avatar
tbernard tbernard is offline
tbernard
Yes, I don't even use the FIOS router. But we don't have FIOS TV, if you do you have to keep FIOS router.
just turn off the wireless and use the Cisco router.
Todd
18 GT3 (VG)
Gone
18 718 Cayman GTS (GT Silver)
14 981 Cayman S (white)
15 991.1 GT3
11 997.2 GT3
96 993 Targa
96 993 C2 tracker
00 986 Boxster S
99 986 Boxster
Old 08-04-2013, 10:11 PM
Yep, you only need the router if you have the TV service. But even if you need to keep the router for TV, you don't have to use the wireless part of it. I used a Linksys wireless access point for years instead of the FIOS ActionTek wireless, and recently upgraded to an Apple AirPort Extreme for faster wifi.
Old 08-04-2013, 11:48 PM
We have the FiOS router (for several years now) and other than an occasional outage, no issues. We have triple-play so need the router, but we use the wireless function on it too without issues.
Old 08-05-2013, 07:44 AM
catron1's Avatar
catron1 catron1 is offline
catron1
My wife and I suffer from several outages daily. It's very annoying, and seems to worse in DC than when we lived in nova. The service outages are so bad that I went to Comcast and swapped out our router, that worked great for two months then bam we have to reset the router two to three time daily...
1980 911sc
2019 Ford Raptor
1987 Mercedes 560sl
2011 BMW M3
1986.5 928s
1987 944 16v
1973 911t
1969 911t "My first car"!!
1969 Westfalia Bus
1973 Volks Superbeetle
Old 08-05-2013, 07:52 AM
lspector lspector is offline
lspector
I had the same issue. Fixed it by purchasing my own wireless router and using it for all of the internal and wireless connections in my house. I still use the old one as the border router, but haven't needed to reboot it in months. Root of the problem is the Actiontec router that Verizon uses.
Old 08-05-2013, 08:05 AM
Maybe Uranus is blocking your signal ?
Old 08-05-2013, 08:55 AM
SilverStreak
I appreciate the replies.
It seems that this morning the wireless is still working. That's a first. I'll see how today goes.
Hunt
611racing.com
OG Racing Team
Vimeo
1999 SPB #611
2004 Wrangler
