Looking at older E46s - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > BMW Technical Discussions » Looking at older E46s
Old 08-04-2013, 09:42 AM
Default Looking at older E46s
Looking at an older E46 323/325 for my son. Preferably a manual. Anything to look for when checking out the cars? Looking at the E46 boards, I know the early models had the subframe cracking problems, but it doesn't look like you can really check on that without a lift and removing part of the rear suspension (which they typically frown on during a test drive). So avoid the 1999/2000s? Or is this overblown? I also read the we'd need to plan on a cooling system overhaul. Anything else?
Old 08-04-2013, 10:00 AM
BeerBurner's Avatar
BeerBurner BeerBurner is online now
Glorified babysitter
BeerBurner
One thing I learned when I bought our E36 (I believe the suspension is pretty much the same as the E46, correct me if I'm wrong) is that the suspension bushings on these cars aren't the most reliable so make sure you check those out. They aren't hard to replace with aftermarket tools so that might even make for a good price reducer should it come up.
BB.
Some say "My car is a Porsche!" I say "My Porsche is a car!" and I drive the hell out of it.
'87 Porsche 944; '10 BMW 328i xDrive (her's); '98 BMW 323is (ours)
Old 08-04-2013, 10:45 AM
Great car just bought one for my 16 YO son, enjoy the search. The AWD does not have the subframe issues. Almost forgot six airbags in the later ones, our 2002 has six bags.
Lucky owner of a couple 911s
1965 Honda Sport 50
Old 08-04-2013, 11:54 AM
^ U have a 914 problem boy-o (sig has way to many)
Old 08-04-2013, 12:34 PM
If rear subframe is already torn/cracked, I've read there will be a hard "clunk" you can hear and feel while driving. I inspected these on my 325 and see zero signs of cracking. ~110k miles. I think the problem is more prevalent on higher HP models, especially those that see autocross/track use.
Old 08-05-2013, 08:23 AM
I'll ping Wong to pipe in here. I think you can see the rear susp bits jut by jacking up the car. I welded his up on his racecar. We had to take everything off to do that obviously but I *THINK* he was showing me what needed to be done before we got that far.
1984 930 - 3.6L
Old 08-05-2013, 08:46 AM
I have a good friend with an E46 325 coupe. His has been reliable, but has needed the shocks and front control arms replaced. Also, the interior trim, especially along the door frames likes to fall down. I have had good success with Gorilla Glue to hold it back up. Also, the kidney grills pop out over time. His trunk release trim also fell off. Before 100K you will want to replace the radiator, hoses, and thermostat. The thermostat is a hole assembly so not as cheap as you might expect.
His car has been tracked many times, but never on track tires and on a stock suspension.. I think if you avoid track tires and a really stiff suspension, the E46 rear subframe mount areas are fine.
Old 08-05-2013, 01:32 PM
magnetic1 magnetic1 is offline
magnetic1
They all have possible subframe issues. Harder to inspect w/ jack but it can be done. Typically driver side has hairline crack which starts it all. typical E36 cooling issues, etc. Take a look at the following checklist. Covers most items:
http://edgemotorworks.com/wordpress/...ing-m-edition/
Wonger
EX-#121 IP/GTS3 BMW E36 M3
HERE-#121 GTS3/4 BMW E46 M3
http://www.Salazar-Racing.com
http://www.brakeswap.com
PM me parts/brake requests and orders. I will donate a portion of order to DorkiBoard!
Old 08-05-2013, 04:21 PM
John Clay's Avatar
John Clay
Not directly E46 experience, but my E39 has now had officially all parts of the cooling system replaced (latest -- auxiliary fan -- put the #of BMW AAA tows in the lead over the fo fo by the way, but for some reason all BMW tows have been with Pam driving even though she rarely drives them). Pretty sure my prior E36 had just about every part of it's cooling system replaced as well. Definitely a plus if this has already been done.
John Clay
2011 Cayman
1986 944 "Traffic Cone"
2013 Scion FR-S
Old 08-05-2013, 06:57 PM
slbates's Avatar
slbates slbates is offline
slbates
I bought a new E46 when they first came out. No track sessions ever but still had the rear subframe tear (under warranty at about 30k miles). Traded it in disclosing the rear clunk that BMW wouldn't fix and took a big hit for being honest. Other problems were rear differential replacement (in hindsight was probably the frame tear), sunroof motor, window regulators and electronic thermostat. I will say the interior was very robust and the leather looked brand new after 36k miles.
Steve
996 GT3
996 C2 (gone)
911SC (gone)
