E36 Cam Install - Dorkiphus.net
Old 07-16-2013, 09:26 AM
arob's Avatar
arob arob is offline
Don't believe the hype
arob
Default E36 Cam Install
***1995 BMW 325is***
This past weekend, I was able to get to the point of reinstalling the head / cams after cleaning up the pistons due to the $$hift at Hyperfest.
Got the cams back in, and hand-tested the turning of cams before moving forward.
Turning the crank, the intake cam turned nicely. However, the exhaust cam turned maybe a couple mm, then snapped.
Thoughts on how I screwed this one up?
I've already got replacement cams, but appreciate input before round 2.
Thanks -
Rob
Rob T.
2006 Carrera S
2013 Cayenne GTS
Old 07-16-2013, 09:53 AM
Wow. Sorry Rob. No idea how to advise (this is outside my current limits of knowledge), but wanted to give you some sympathy.
Old 07-16-2013, 10:05 AM
tank tank is offline
tank
I had once thought of upgrading my e36 camshaft until reading this.
Piece of cake, I thought, until I learned that the BMW camshafts are not like many others that I had worked on previously. Particularly on the six-cylinder cars, the camshafts are very long and hollow. This makes them very susceptible to bending and adverse side loads that can be placed on them during the removal process. After consulting the BMW factory documentation, I quickly realized that BMW requires you to use a special tool in order to remove the camshafts. "No problem," I thought. "I'll just purchase the tool and then rent it out through Pelican for others to use." Well, that well-thought out plan went right down the drain when I realized that the tool costs over $1400 and isn't even available for purchasing at this time. The story I received from our BMW dealer was that the tool is specially made by one guy, in some small company, in the motherland of Germany. There would be an eight-month lead time for delivery of the tool, and even that wasn't guaranteed. In addition to that, you had to buy two tools - one for the four cylinder engines, and an adapter add-on tool for the six cylinder engines.
http://www.pelicanparts.com/bmw/tech...ft-removal.htm
Frank
85.5 944/951/s2
13 FRS
Old 07-16-2013, 10:39 AM
I miss the good ol' days of easy to work on cars.....
Old 07-16-2013, 12:10 PM
Seems cheaper to just buy a NEW camshaft and not worry about removing the old one!
Old 07-16-2013, 12:13 PM
arob's Avatar
arob
Actually would have been cheaper to just buy a replacement motor.
Rob T.
2006 Carrera S
2013 Cayenne GTS
Old 07-16-2013, 12:17 PM
How much is a replacement motor for a SPEC-3?
Let me know when the next BMW-CCA club race is at Summit Point. I'd love to come up and see what it's like. How do the racers differ from PCA racers? I would assume it's between NASA and PCA, but closer to the young and wild, or the older/richer?
Old 07-16-2013, 12:53 PM
4Rings's Avatar
4Rings 4Rings is offline
4Rings
Young and wild guys are usually up front, the older and richer racers are in the back of the pack. Rob runs in the very select mid-pack group of older but not-so-rich drivers :P
Tomasz
'03 Ford Excursion 6.0 Diesel - Tow Vehicle
'06 Porsche Boxster S - Daily Driver
'19 VW Beetle Final Edition - Missus DD
'06 Nissan 350Z Track Car
Old 07-16-2013, 12:56 PM
This thread is getting long, and no one has yet posted anything helpful for Rob's issue.
Old 07-16-2013, 01:51 PM
May be quite a bit cheaper to just buy another stock head. Heck, if you can find a cheap enough motor, get the whole thing.
1984 930 - 3.6L
