Porsche 997.2 Rear Pad Change - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Porsche 997.2 Rear Pad Change
Old 05-14-2013, 11:28 AM
SRosu SRosu is offline
SRosu
Default Porsche 997.2 Rear Pad Change
Hello, I am looking for some advice or help with changing the rear pads on my 997.2. I have done pad changes before on other cars but I am a little nervous about working on this car without some direction/ supervision.
The main difference between my rear calipers and all of the DIYs I have found for air cooled models is that my 997.2 rears are closed so you cannot just simply slide the pads out. Caliper removal does not look complicated (just two bolts I believe) but I am not sure how easily the pads will slide away from the rotor, what other pieces need to be changed along with the pads, if any clips will pop out once the pads are out, torque specs, etc.
Any help is appreciated. This is my first time posting here but I love reading the threads here as it helps me learn more about my car!
Cars:
- 2010 Porsche 997 C2
- 2007 Mercedes CLK 350
Old 05-14-2013, 11:39 AM
Welcome! I don't know the specs or what exactly it looks like but welcome to he board and jumping in to do the work yourself.
Old 05-14-2013, 03:40 PM
spiffyjiff's Avatar
spiffyjiff
some may chime in but there are not too many on here with a 997.2 (that also DIY, etc). try searching rennlist or 6speed for DIY tutorials for brakes.
Chris M.
Old 05-14-2013, 03:44 PM
ausgeflippt951's Avatar
Shock Whisperer
I thought you did have to remove the caliper for these? Ryan would know I should think.
Welcome.
Collin M.
I wear a cowboy hat.
'06 M3: hers.
Old 05-14-2013, 03:56 PM
Ryan's Avatar
Ryan Ryan is offline
Have a Grateful day
Real easy. It's actually 2 bolts and a screw.
1) take rear wheel off
2) remove screw behind caliper which holds the brake line bracket to the hub. I screwed this up first time I did it and didnt remove this screw ( my 1 GT3 didnt have this) . Bent the bracket all up and was always a pain to change pads since then.
3) remove 2 bolts holding caliper on. they are "stretch" bolts, so Porsche says replace them each pad change. I did it about every 3rd change and never had a problem
4) wiggle caliper and try and compress pistons as much as you can
5) slide caliper off
6) pop pads off
7) compress pistons (i did it by hand) all the way in on one side, put pad on
8) compress pistons on other side and put pad on
9) replace caliper
10) line up perfectly and screw bolts by hand. MAKE SURE YOU HAVE THEM ALIGNED/THREADED CORRECTLY. You strip the thread and you're screwed. Then use ratchet and torque to 63lb
11) screw brake line bracket back in
Ryan (Wahooooo....)
'19 991 GT3 RS Weissach
'08 997 PCA H class
'89 930 Targa
'18 F150 Raptor
'16 991 GT3 RS
'18 991 GT2 RS
'16 AMG GT S
'10 997 GT3 RS
'07 997 GT3
'09 Aston Martin DBS
'96 993 H Class
'14 F150 Raptor
Old 05-14-2013, 04:00 PM
Ryan's Avatar
Have a Grateful day
Also over time the dust boots crack and the pucks fall out when removing the pads. Makes pad changes a bitch. You can get cup car puck holders which keeps them from falling out. Eddie at racepartswarehouse.net sells them. Well worth it and fairly cheap.
Ryan (Wahooooo....)
'08 997 PCA H class
'89 930 Targa
'18 F150 Raptor
'16 991 GT3 RS
'18 991 GT2 RS
'16 AMG GT S
'10 997 GT3 RS
'07 997 GT3
'96 993 H Class
'14 F150 Raptor
Old 05-14-2013, 06:51 PM
^ GT3 cheap or ROW cheap???
Old 05-14-2013, 07:56 PM
B r i a n's Avatar
B r i a n B r i a n is offline
B r i a n
I am pretty sure they are the same as a 996:
Here are some videos:
http://forums.rennlist.com/rennforum...-tutorial.html
I plan to change mine in a month or so if you want to watch/help, thinking of replacing rotors too.
Last time I changed the rear pads, I remember it was very, very easy.
2024 Lotus Emira FE V6 Manual
2005 Lexus SC 430
2007 Turbo - sold in 2023
1966 912 - sold in 2022
2005 BMW X3 - sold in 2022
1975 Vette - sold in 2015
2004 Cabriolet - sold in 2013
1977 924 - sold in 1991
Old 05-14-2013, 08:37 PM
997.2s are differrent than my 996. It's an early 996 so...
Old 05-14-2013, 10:54 PM
SRosu
Ryan this is excellent advice, thank you. By pucks are you referring to the vibration dampers? I am guessing the pucks/ vibration dampers are inside the piston and normally I would not touch those when doing the pad change correct?
Cars:
