My co-worker has a 5 Series and the interior heat never really gets hot. He said even with the temp set on 80 it will only ever get about luke warm. The other issue he is currently having, he said the temp has a auto sensor, and that sometimes the fan will be off and then just come on full blast. He said the fan coming on full blast happens when the settings are at 64-80.
Anyone have an idea on what might cause these issues? Thanks
E34, E39, or E60? I assume not an F10 otherwise it'd be at the dealer getting fixed under warranty.
i had lack of heat problem like that in the jeep. The heater valve wasnt opening, allowing the hot coolant to the heater core...likely getting a little warm just from the heat of the engine...was an easy fix once i figured out how the system worked..
I've never RTM'd on my E39, but I have to manually adjust the temperature on the dial next to the vent in the center of the dash to get temperature I want. Adjusting the auto temperature control on the console by itself doesn't do the trick.
The full blast could be from the auto setting waiting until the car gets warmed up before it blows heat, then it says "you want it hot, I'll get it hot".
FWIW, the heater on my Landcruiser went out a while back. Barely warm even with the controls set to max temp. Checked all the usual stuff, but no luck. Like most reasonably modern cars it does not have a heater control valve. Hot water flows through the core constantly and the air mixer doors take care of the temp delivered to the cabin.
Finally popped the cabin temp sensor, which was covered in many years of dust and frass. Gave it a good cleaning with IPA/water and a soft brush. Everything worked perfectly after that.
Funny you posted this. I'm driving a friend's 2000 540i for the winter (also his Maserati) and even though the heat is set to 63 degrees on both sides (the lowest setting) it constantly blows HOT unless turned completely off. Perhaps we should get the cars together for a compromise...
Anybody know where the cabin temp sensor is in these cars?
Peter (not "Pete") K. 1997 Spec Boxster 2016 Cayman S 1999 Miata ("SM") race car 2016 Toyota Highlander--tow vehicle/wife's DD 2017 VW GTI SE (DD) Gone and missed: 1992 Miata ("SSM") race car 2009 911 C2S Coupe 2004 Toyota Prius - sold to son's girlfriend 2006 Dodge Durango 2003 Acura MDX 86 Black 911 Coupe race car 86 Gold 911 Targa 82 WineRedMetallic 911 Targa |
![]() Quote:
Thanks. I'll look on the dashboard later.
![]() Quote:
Thanks guys. I've passed the info on to him.
Jazz- its a 525. My bad, I have no idea what the internal BMW designation is, I'm not a BMW guy. Now if you'd ask me about Jeeps internal designations, I'm your guy. ![]()
