question about motors - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > BMW Technical Discussions » question about motors
Old 01-09-2013, 09:31 AM
Tito
86911TLCAB
Default question about motors
I purchased a used motor/window regulator for my E30. Works fine on descent and fine about 3/4 of the way up. Then it begins to slow down and stops about 2 inches from the window closing.
when i test it out of the car, it opens all the way, then closes all the way.
Is this a sign the motor is possibly going bad, or is it likely the cabling is messed up?
any thoughts appreciated before i go return this and seek another...
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
97 Lexus SC300 Manual
86 TL (gone)
993 (gone)
75 911S (gone)
Old 01-09-2013, 09:36 AM
Sounds like there is some friction in the regulator. Without the motor, can you move it freely through its whole range of motion?
Old 01-09-2013, 09:44 AM
APKhaos's Avatar
APKhaos APKhaos is offline
APKhaos
There's dirt and crap built up in the window channels. Probably what killed your last motor. Check/clean the window channels. Once you get them clean, hit them liberally with silicon spray.
Tony K
PCA Potomac, Rennlist Member
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 01-09-2013, 09:47 AM
arob's Avatar
arob arob is offline
Don't believe the hype
arob
Tito - if it turns out to be the motor, I've got a spare from an E36. Not sure if they're compatible.
Also, as Tony stated - clean out the channels, and check the plastic guides as well.
Rob T.
2006 Carrera S
2013 Cayenne GTS
Old 01-09-2013, 09:51 AM
Tito
86911TLCAB
The assembly does not allow the cabling to move without the motor (as far as i can tell). butchered another regulator assembly trying to see if i could repair it.
didnt even think about the window channels...will clean up and see if that is the cause...
as i said the thing works fine when disconnected from the window (or outside the car)...i just figured it was the load of the window causing the problem...thanks...try later and hopefully resolve the issue.
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 01-09-2013, 05:40 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
Had the same issue on the daughter's VW. Ended up being a frayed cable in the regulator. It would work fine with no load but with the weight/friction of the window plus the frayed cable there was enough total friction to cause the window to stop about 3/4 of the way up....sometimes making it return to the down position. Had to replace the regulator.
89 944 Turbo Race car
98 993 C2S w/Aerokit II
70 Boss 302
86 Mustang SVO
24 F250 SD Godzilla
Old 01-10-2013, 09:10 AM
Tito
86911TLCAB
cleaned it up...checked the cabling and it appears ok end to end...and it is working fine...thanks to all for the help.
Follow on question: anyone know of a suitable replacement for the plastic moisture barrier which is locally available?
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
Old 01-10-2013, 10:16 AM
I've seen 6mil poly sheet or even a trashbag used.
Old 01-10-2013, 10:40 AM
Tito
86911TLCAB
ok...so doesnt really have to be anything special...thanks...
Tito
82 911 SC with 3.2
73 RSR project
97 328is
99 328is
86 TL (gone)
993 (gone)
75 911S (gone)
