HPDC for Wifey - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » HPDC for Wifey
Old 04-06-2012, 10:51 AM
RedOctober's Avatar
RedOctober RedOctober is offline
RedOctober
Default HPDC for Wifey
My wifey will be attending, in my daily driver as we are still getting her up to speed driving a manual.
How much lapping will they do in the afternoon? Just trying to gauge what kind of wear I'll have to my tires.
Anyone here instructing?
_______________________________________________
Tim M
'00 C5 Corvette FRC track car
'86 944 N/A (aka Doublemint) - Past
'20 Ford Expedition Max
Old 04-06-2012, 10:55 AM
John Clay's Avatar
John Clay
Kind of hard to guage wear on tires without knowing how hard she'll drive. Biggest tire killer for most novices would be skid pad, but S.P. has a wet skid pad, so no problem there.
John Clay
2011 Cayman
1986 944 "Traffic Cone"
2013 Scion FR-S
Old 04-06-2012, 11:00 AM
Tires should be fine. Afternoon will be 2 - 3 20+/- minute sessions. Another session will be instructor taking student for ride, usually in instructor's car, but sometimes in student's car.
Skidpad will be fine on the tires, due to wetting down and John mentioned.
Brakes may take a beating during the braking exercise. Don't want to be too low on the pads. Also, if not difficult, consider disconnecting the wear sensor wires. Student will be pushed to ABS activation repeatedly, and heat can build up. Seen one student whose car cooked the insulation on the wear sensor wires up front. Of course if car is non-ABS, flat spotting tires could be an issue.
Old 04-06-2012, 11:18 AM
Did you say what kind of car the DD is?
I'll be there instructing. Look forward to meeting your wife and all the other newbies, too.
Old 04-06-2012, 11:22 AM
RedOctober's Avatar
RedOctober
Pontiac G8 GT....I do have good fluid and better pads on it, so it should be OK. Skidpad should be a hoot in it. I am jealous!
She has done a couple track days in the past but it has been years (pre-kiddos). Might as well get this HPDC out of the way so she can run with PCA once she is up to speed on manual.
Thanks for the feedback guys......I just wasn't sure how many lapping sessions they do.
Tim M
Old 04-06-2012, 11:27 AM
Rick K's Avatar
Rick K Rick K is offline
Rick K
My wife did the HPDC a few years ago and had a blast. Tire wear wasn't even a thought in my mind for a day on street tires. Now flat spotting would be a different story.
1985.1 944 - Brown
98 M3 - Silver
84 RoW Coupe - Guards Red
86 911 - Black
95 993 - Silver
80SC - Hellblau
73.5T - Sepia
Old 04-06-2012, 11:58 AM
Been dong this a while and have yet to see an HPDC participant lock up the wheels enough to flat spot! There's only one excersie where it really is an issue. But most at the first sign of lock up simply release the brakes. Plus ABS helps newer cars.
Old 04-06-2012, 01:56 PM
GT3's Avatar
GT3 GT3 is offline
GT3
car will be fine. new drivers are slow drivers, easy on brakes and tires. As long as they don't hit a wall.
Clarke
68 912
75 911S Gemini Blue 3.0L
10 GT3
18 S6
22 F250 King Ranch
Gone:
18 F250 King Ranch
12 F450 Lariat
11 GT3RS silver
11 GT3RS white
10 Cayenne GTS
08 Cayenne S
06 997 C4S cab
(2) 05 997S C2 Launch
04 M3 Laguna Seca Blue
02 996 cab
91 964 C4
82 911 SC Euro 3.0
(3) 78 911 - 3.2
77 911
75 911S
73.5 911T
73 911T
72 911T
71 911T RSR vintage racer 3.0
68 911
Old 04-06-2012, 07:13 PM
AS2003 AS2003 is offline
AS2003
Default Another Newbie Question
I've seen cars with painters tape on them at Summit Point, presumably to protect from rock chips at the track. Is this something you veterans would recommend for HPDC? Thanks in advance.
Old 04-06-2012, 07:37 PM
track density isn't anywhere near as high as DEs. Still covering head lights and parling/fogs would be prudent. Early morning check + doing this at track = much lower fun facter.
