928 will not idle and stalls - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » 928 will not idle and stalls
Old 12-09-2011, 10:43 AM
Baywatch's Avatar
Baywatch Baywatch is offline
Baywatch
Default 928 will not idle and stalls
My 1979 928 will not idle and stalls after start up. I can keep it running at 2000 RPM's. Any suggestions?
Old 12-18-2011, 12:04 PM
What type of fuel injection on a '79? Kjetronic or derivative therof...?
Old 12-18-2011, 09:14 PM
Lt. Dan Lt. Dan is offline
Crush all cones!!!
Lt. Dan
Checked for vacuum leaks?
Dan
'03 Mini Cooper S
Cone Dodger
Old 12-18-2011, 09:44 PM
A 1979 928 has k-jetronic aka CIS. Maybe the SC CIS experts can help out.
Old 12-18-2011, 09:53 PM
markwemple's Avatar
markwemple
Have you done any work to it recently?
2002 C2 Cab
1982 911 SC Targa
1978 911 SC Targa
1976 911 S Targa
Formerly:
1964 scca C coupe
1965 C coupe
1968 912 Targa
1970 914/4
1985.5 944
(glutton for punishment)
Old 12-19-2011, 01:08 PM
turbo23dog's Avatar
turbo23dog turbo23dog is offline
turbo23dog
I had a similar problem on a 1987 Merkur XR4Ti and the Vane Air Meter (VAM) was bad. I think the 928 has a VAM too...
Rich F.
2017 BMW M240 xDrive Vert
2004 BMW 330Ci Coupe (DD)
1996 BMW 328i
2006 Cayenne S
1980 SC Targa (A1R KULD)
2010 Boxster S (sold)
2000 Boxster S (sold)
73 911T Targa (sold)
67 912 (sold)
Old 03-02-2012, 09:53 PM
SMTCapeCod SMTCapeCod is offline
SMTCapeCod
No VAM.
It is K-jet CIS, no lambda. APpears to be a Euro, too.
Auxiliary Air Valve may be out of service.
Or, if it has been parked for some time, you may have some precipitant caught in the screens in any one of a number of places in the fuel system. Most likely culprits are under the fittings in the Warm Up Regulator, and at the fuel input to the Fuel Distributor (FD) on the lower right. System fuel pressure regulator in the FD might be stuck too, but that is uncommon in my experience.
Hope you post up the resolution if it is solved.
