964 Starting Issue Help Please - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » 964 Starting Issue Help Please
Old 08-16-2011, 10:24 PM
swftiii's Avatar
swftiii swftiii is offline
swftiii
Default 964 Starting Issue Help Please
Dorki's,
Such a great weekend at Summit, but a new issue has come up with the car and i'm looking for a little advice on how to do some diagnostics.
Problem: The car has decided it doesn't like starting up immediately like it used to a couple weeks ago. Now about 75% of the time I have to crank it for a good 5-8 seconds before it will start up. I believe the long start is more tyical when the car is hot, but haven't been able to prove this point. Another piece of information is that the 'check engine' light comes on briefly, but then goes out. I don't have a Hammer, so can't pull any codes, but when I try the gas pedal method there are no codes flashed back.
Once the car starts it runs smoothly and as expected.
David Riley (thanks!) suggested I check the ignition coils and/or control units, but instead of just replacing them I would like to know how to test them. I have not dealt with these before and am a complete novice (but willing to learn), so any help is greatly appreciated and welcome at an elementary instructional level.
Thanks all,
-Skip
Skip
'91 964 #54
'97 993 C4S
Old 08-16-2011, 11:06 PM
Richard Curtis's Avatar
Richard Curtis
skip: If you're not aware of its existence, Rennlist has an excellent 964 forum that's proved helpful to me on many occasions. Sounds to me like you might have a fuel-delivery problem. A very common problem on 964s is a failed or failing DME fuel relay (best advice from many 964 owners is always to carry a spare DME fuel relay since they fail often). If you have the extra one, you might try popping that in to see if it cures the problem.
Richard Curtis
Old 08-16-2011, 11:16 PM
Charlie Stylianos's Avatar
Agreed, or possibly loss of fuel pressure to injection system. Do the 964's have a fuel accumulator or something similar?
Kyriakos E. Stylianos
Baglama inspired
Old 08-16-2011, 11:29 PM
swftiii's Avatar
swftiii
Richard - thanks I've been on Rennlist for a long time and have posted over there too, but like to gather information from as many sources as possible.
I already replaced the DME Relay (should have listed that in the OP) and nothing changed.
Charlie - not sure about a fuel accumulator or similar.
Should I consider installing a new fuel filter? I'm not sure how long it has been since it was replaced. How do I test the ignition coils?
Skip
'91 964 #54
'97 993 C4S
Old 08-17-2011, 07:47 AM
Asked that too, thought you said you had changed it.
Might want to explain the other symptoms too. Didn’t you say after cranking for a couple of second if yo pressed on the accelerator it would start.
Old 08-17-2011, 07:59 AM
swftiii's Avatar
swftiii
David - on your recommendation I tested without touching the accelerator and it was, as you thought it might be, coincidential. It will startup without hitting the gas after the 5-7 second mark.
I'll try to look through my service records to see when the fuel filter was last changed, but I'm not sure. It doesn't look old as I look at it, but that doesn't mean anything.
So where to start and how can I check if the coils/ignition controls have issues?
Thanks all - I will have some time tonight to look at it.
-Skip
-Skip
Skip
'91 964 #54
'97 993 C4S
Old 08-17-2011, 08:22 AM
Test for spark with an inductive timing light on the coil to dizzy wire. See if the timing light blinks during crank but no start portion of the starting cycle. If it does you might want to look at fuel. Sounds like the fuel pressure is dropping off.
Old 08-17-2011, 09:42 AM
Paddy's Avatar
Paddy Paddy is offline
Paddy
I thought you might be interested in reading this web page:
http://forums.rennlist.com/rennforum...ferrerid=24812
From,
Paddy
16 GTI
02 BMW Spec E46 #27
01 Boxster
86 944- AER/Chump #33
20 F250 Tremor
Old 08-27-2011, 02:40 PM
RunningonMT RunningonMT is offline
RunningonMT
Skip,
Any update on the hard starting problem with your 964? I have a similar problem with my '93 C2. As a matter of fact, its sitting in the middle of the garage and won't start! (Just changed the brake pads.) Wife's car is outside in the hurricane waiting to come inside for safety!
Rick
Rick G.
Black '93 964 C2
#421
Running on, running on empty,
Running on, running blind,
Running on, running into the sun,
But I'm running behind
- Jackson Browne, 1977
Old 08-27-2011, 03:09 PM
swftiii's Avatar
swftiii
No update...sorry. I'm taking it to ASG on Wednesday this week as I haven't had any time to do anything.
Sorry.
Skip
'91 964 #54
'97 993 C4S
