I believe the Dawe engine is ready to install, but unfortunately Peter D has been unresponsive by email or phone for several weeks (he's not young - I hope he's okay). So I'm posting here.
The photo shows the vacuum caps replacing several small and one large hose on the back of the "air box" (#21 on the PET image). Any of these not okay in terms of engine management/safety/power as far as any of you know? Both Peter D and Charley Murphy said it's reasonable to replace the breather hose between the oil tank and the air box (see the large red plug in the photo). Also replaced/plugged are the two hoses on the "thermo valve" (#13), and the two others on the throttle housing (#9): the intake that hose #28 goes to, and the other unlabeled one. Finally and most importantly, any secrets before starting an engine that has not been started for about 2 years? Please tell me now while it's still off the car and doing stuff is easier... I do want to thank Bill Miller and Froggers911 (Frankie) for loaning me TWO engine stands - which made transfer of the exhausts, etc. much easier. Bill also loaned me a couple of very special tools for which I'm appreciated (and didn't mess up -- sorry Dave).
Peter (not "Pete") K. 2025 Lucid Gravity Grand Touring (on order, future tow vehicle) 1997 Spec Boxster #671 2016 Cayman S 2016 Toyota Highlander--tow vehicle/wife's DD 2017 VW GTI SE (DD) Gone and missed: 2003 Miata ("SM") race car 1992 Miata ("SSM") race car 2009 911 C2S Coupe 2004 Toyota Prius - sold to son's girlfriend 2006 Dodge Durango 2003 Acura MDX 86 Black 911 Coupe race car 86 Gold 911 Targa 82 WineRedMetallic 911 Targa |
Usually turn it over a few times by hand (easier with plugs out). Then with starter motor to build some oil pressure before fire up. Of course you checked the intake runners to make sure nothing dropped/fell into them.
David I hope to arrive to my death, late, in love, and a little drunk! Just because I don't care doesn't mean I don't understand... Homer Simpson "That's what's keeping me out of F1.... Too much mental maturity...." N0tt0n Some cause happiness wherever they go; others whenever they go. CHAOS, PANIC, AND DISORDER my work here is done... Live without pretending, Love without depending, Listen without defending, Speak without offending Last edited by Trak Ratt; 08-09-2011 at 12:03 PM. |
Yes you can cap those hoses - I nuked the whole set involving the #31 valve on my 3.2 conversion. It's supposed to help keep condensation from icing up in the oil tank or something like that. All the non-3.2 cars don't even have the system. Doesn't seem terribly important in our climate.
Jeff S '14 991.1 Carrera S Coupe '25 Cayenne E-Hybrid '11 997.2 Carrera S Cab '09 987.2 Cayman S '12 Audi TT-RS '05.5 Audi S4 '20 GMC Tow Beast '06 987.1 Boxster S '17 718 Boxster |
You could pull the fuel pump fuse or relay and crank it for awhile to get oil to the pistons and other parts before firing it up. Seems prudent to me.
x2. This is the typically accepted procedure for new motors. Disable fuel. Crank until you have oil pressure. Then crank for another 20-30s to make sure all the oil galleys are full (all he way out to the far end of the cams.)
Stephen www.salazar-racing.com 1970 914/6 - 3.0L GT 1983 911SC - 3.32L IROC 1984 930 - 3.6L dirt bikes (some gas, some electric), Sherco trials bike Sold: 2001 Boxster (hers), 2003 996tt x50 ![]() |
Also a good time to check for fuel leaks.
That's quite the 'engine room' you have there, good progress. Now you just need to get rid of one of them
'64 356 SC '73 914 2.0 (2.8/6 conversion in progress) '65 Ducati Falcon 80 '67 Ducati Cadet 100 4-speed ‘19 SQ5 Gone but not forgotten: '02 S6 Avant - trans blew, but rebuilt as a 6-speed by new owner '99.5 A4 2.8QT - tree fell on it after 20 years ‘74 MB 280C - traded for paint/rust repair/6-conversion mods on the 914 ![]() |
![]() Quote:
That's that way I do it when my car has been sitting for a month. Pull fuel pump fuse (it's fuse number 6 in a Carrera fuse box). Crank until oil pressure warning lamp goes out.... can take several seconds of cranking sometimes. Restore fuse. Start engine.
Thanks, everybody. I'll get the oil around it before letting it fire (and fuel). Couldn't I accomplish the same things by just leaving the (still disconnected) fuel pump relay disconnected? I will hand crank it a couple of spins before applying electricity, but not with the plugs out as I won't be filling it with oil until it's back in the car.
