Don't want to have to get a NASA or SCCA license so what other events are local in June that I could drive in?
Hyperfest (if not too late to register)? FATT?
Larry -- go to SP's web site and look at the schedule -- they usually provide links to the clubs so it's easy to contact them.
The calendar shows nothing for June unless you have the SCCA or NASA license.
You don't need a license to do DEs run by NASA or SCCA.
I didn't know that. I'll go and re-check.
But you do need to be a member. NASA is sweet cause membership includes 12 months of Grass Roots Motor Sport
Yes, Larry, what license are you talking about? You just go and sign up; you can even sign up to level 3 and provide explanation on your background and DE experience, they'll still put you in level 2 first, but probably move you to L3 later in the day or weekend.
You have to be a member, if that's what you meant by 'license.' But that's just one a year, no big deal. I personally don't waste money on SCCA for DEs.
Cheers, Fatih |
Ben is planning on signing up for NASA HPDE the same weekend I'm racing (if he's coming all the way down to VIR with me, I want him to drive). HPDE-2 has some overlap with the racers, but HPDE-3 does not. Am I hearing that Ben, who is generally signed off solo in Blue plenty early each event, could conceivably sign up for HPDE-3, knowing they'd put him in Level 2 for the first few sessions?
