An event worth learning - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » An event worth learning
Old 06-02-2010, 08:37 AM
OldTee's Avatar
OldTee OldTee is offline
OldTee has one HoF thread
Default An event worth learning
from. Yesterday I went to start the blue car and heard the familiar "pop" of a lean condition upon cranking. It was the second trip of the day and the engine was warm, the day was warm. The car would not start.
I went back and removed the air filter and found the pop-off valve had un-set. Put some silicon paste on the gasket, reset it and went on my way.
This car has a new style box and really does not need the pop off valve. The older box was replaced because it did not have a pop off valve.
If you have an older box I would suggest install a pop-off valve. It is not a difficult job but some care is required to seal it properly, orient it in the proper direction and make sure it is put in the correct place.
ARF
OldTee
Sold 79 911SC
1991 Corvette
Capital One is the pits!
Old 06-02-2010, 12:24 PM
racer's Avatar
racer racer is offline
racer
I can't imagine a CIS 911 without a popoff valve. I missed way too many kindergarden days waiting for the flatbed to tow our then new '74 to the shop.. Mom wasn't happy either
Dave
- 1970 914-6
- 2000 Boxster
- 1987 944
- 1987 924S
- 1978 911 Euro SC
- 1976 914 2.0
- 1970 914 1.7 / 2056cc
Old 06-02-2010, 12:42 PM
type954's Avatar
type954 type954 is offline
type954
Also, it's important to locate the hinge of the pop-off valve in a position to insure the lid/cover doesn't foul on the airbox.
Old 06-02-2010, 03:11 PM
Mark Mark is offline
Mark
Same thing happened to me. I checked spark and fuel before thinking to open the airbox and check the pop-off, which had popped off. I reinstalled it using a lot more epoxy.
1982 SC
2003 Saab 9-3
1999 Corvette (son's)
2003 Eclipse (daughter's)
2003 Intrepid (wife's)
