Hi finally getting the registration tomorrow!
After one year and four months i'm going to take the car on the road for a serious drive and i was curious, what fuel do you guys recommend to use. the only modification is the catalytic by-pass. Can wait to fill up the tank Thank you See you guys out there maybe, the car is in Arlington behind the costco. |
Run high test for a while (couple tanks) then down one grade. Try and find the some non sumer stuff too. If you hear any detonation go back to high test.
<O <O
David I hope to arrive to my death, late, in love, and a little drunk! Just because I don't care doesn't mean I don't understand... Homer Simpson "That's what's keeping me out of F1.... Too much mental maturity...." N0tt0n Some cause happiness wherever they go; others whenever they go. CHAOS, PANIC, AND DISORDER my work here is done... Live without pretending, Love without depending, Listen without defending, Speak without offending Last edited by Trak Ratt; 05-14-2010 at 10:40 AM. |
One tank of high test, agree with that one. After that, regular is fine. Your engine is 8.0 or less compression ratio. At the track go high test. Hint: turn the fuel nozzel upside down, ie pointed away from you. Some 911s don't feed well the other way and it takes forever to load up. Re: Avitar, Use the one Trak uses. He does and he does not have the equipment! ARF
OldTee Sold 79 911SC 1/2 87 Carrera (I fix daughter drives) 1991 Corvette Need locks don't use H & H Lock Company Capital One is the pits! Last edited by OldTee; 05-14-2010 at 10:34 AM. Reason: added hint |
so 91 one tank, then regular.
93=high test. 87 should be avoided. 89 and 91 work just fine in my 2.7, but I always tend to put 93 in for that extra $1.50 of clean burning safety margin.
my avatar, complete random i didn.t meant to offend anyone. just found the pictures of a search for my avatar if it is personal, please let me know i will remove it
Thank you. |
No one under 70 calls it " High test " any more
Scott Bresnahan Purcellville Va. 2014 GTB1 World Champion 8 Time National DE champion 88 911 Cup 2021 GT4 13 Boxster S 1969 Saab Sonett 2013 Cayenne 2014 F150 Hurricane race trailer with A/C 05 Cup car 02 Koni 996 |
well there you go!
I'm under 70! Way under. ...but I haven't called it hi-test for about 20 years.
