Lazy man engine pull - Dorkiphus.net
Old 12-27-2009, 09:20 PM
OldTee's Avatar
OldTee OldTee is offline
OldTee has one HoF thread
Default Lazy man engine pull
not in any hurry. Today (12/27/09) made the first steps to remove the engine in Michelle's 87 Carrera to reseal the cam towers which are leakin/seeping oil, by clearing the lift. The black car is in the shed, the blue car behind the lift. Tues I will bring the Carrera over and put it on the lift and drain the oil. On Wed (or so) I'll start pulling stuff. Step by miss step progress will be documented here.
ARF
OldTee
Sold 79 911SC
1991 Corvette
Capital One is the pits!
Old 12-28-2009, 09:23 AM
type954's Avatar
type954 type954 is offline
type954
Wink
Mis-leading title of the thread. I thought a lazy man engine pull was to take out the plastic....
Old 12-29-2009, 05:38 PM
OldTee's Avatar
Step one
Make room for a car.
OldTee
Sold 79 911SC
1991 Corvette
Old 12-29-2009, 05:39 PM
OldTee's Avatar
Step two.
Put a car in the space.
ARF
OldTee
Sold 79 911SC
1991 Corvette
Old 12-29-2009, 08:20 PM
That looks like enough work for one day to earn yer beer.
Old 12-29-2009, 08:32 PM
The suspense is killing me.
Old 12-29-2009, 08:56 PM
OldTee's Avatar
Mee too
ARF
OldTee
Sold 79 911SC
1991 Corvette
Old 12-30-2009, 11:40 AM
marsosporsche's Avatar
marsosporsche marsosporsche is offline
marsosporsche
how much did your lift cost you? installed it yourself
thank you
Old 12-30-2009, 12:06 PM
Parenn911's Avatar
Loose Lips Sink Ships
Parenn911 has one HoF thread
You forgot a step.
Old 12-30-2009, 12:45 PM
gjnolte's Avatar
gjnolte gjnolte is offline
gjnolte
thank you
The lift is a Bend Pak MD-6XP. I have the same one in my garage. It's a Mid-Rise scissors lift with a capacity of 6000 lbs. As for install, there's virtually none as you can move it around with the use of the dolly which the pump is mounted on. However, there is some assembly required. I just did a quick Google search and found prices between $1845 and $2250. I'm sure you can shop around to find someone who wants to move some stock. Be sure to include shipping (and possibly "Home Delivery")
Greg Nolte
'86 911
'87 325iS
'91 318iC - back together....
'91 318iS - not yet titled or tagged..STILL
