911 sc cylinder stud removal, any tips? - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » 911 sc cylinder stud removal, any tips?
Old 07-14-2009, 10:39 PM
marsosporsche's Avatar
marsosporsche marsosporsche is offline
marsosporsche
Default 911 sc cylinder stud removal, any tips?
i'm replacing finally all the gaskets of my engine, had some dificulty already with exhaust studs (3 broken ) and (fixed) ,
But i'm more concerned for the cylinder studs .
please if you have aNY tips, it is for tomorrow wednesday
thank you
Old 07-14-2009, 11:07 PM
OldTee's Avatar
OldTee OldTee is offline
OldTee has one HoF thread
do you have any evidence of a broken stud? Don't equate exhaust studs with cylinder studs. Don't make problems until they occur. A Porsche engine has so many rattles, barfs, sputs, gurgles, clashes, chain noises and such, you can chase non problems all over the place.
ARF
OldTee
Sold 79 911SC
1991 Corvette
Capital One is the pits!
Old 07-14-2009, 11:32 PM
If you are replacing all the gaskets I assume that means you are tearing the engine completely down. If so, I assume you are at least having lots of parts measured and checked at the machine shop. Have them replace the stubborn exhaust studs. If they dont come out with a good dose of heat, let the pro setup the head in his drill press and earn his $$.
Old 07-15-2009, 06:45 AM
marsosporsche
thank you so you think that the studs should come out, if they are not already broken.
right?
I do that with alot of passion and time myself and not to much money so i thank you very much and hope to post so pictures of my baby some days.
engine runs stong with no smoke, but leaked @ bottom cylinder gasket and and headgasket.
Old 07-15-2009, 06:58 AM
On the cheap: You can double nut the studs and add heat w/ a propane/mapp torch and get them out. If you're not going to reuse, you can even be as barbaric as welding nuts onto them.
For alot more money: A proper collet based stud puller (still w/ heat) will be easier and not damage threads.
http://buy1.snapon.com/catalog/item....re&dir=catalog
1984 930 - 3.6L
Old 07-15-2009, 08:40 AM
OldTee's Avatar
Sorry, I misunderstood your direction. Here are some pictures that may help. This shows the studs coming out and going back in. Use correct tools wherever possible.
ARF
OldTee
Sold 79 911SC
1991 Corvette
Old 07-15-2009, 09:38 AM
marsosporsche
thank you very much, i really appreciate.
will keap you posted.
Have a good day.
Old 07-16-2009, 06:38 AM
marsosporsche
I found 5 broken studs!
the chain tensionner shows, 930+++++++ are those the oil ones? or the old ones?
thank you
911 sc 79
Old 07-16-2009, 07:33 AM
OldTee's Avatar
If you don't have one, buy "How to rebuild & modify Porsche 911 Engines" from Pelican. Get it today, and don't go forward until you read it and have an understanding of what you are dealing with. Your questions should be answered there.
If you had to remove an two oil lines to remove the chain tensioner housings then they are oil feed. Mechanical chain tensioner have a nut on them.
Good luck.
ARF
OldTee
Sold 79 911SC
1991 Corvette
