'85 911.
Prepping to fix an unknown oil leak at the front of the engine. Have all requisite parts - crankcase breather gasket, breather hoses (3), oil pressure switch, t-stat o-ring, and 3 oil cooler o-rings. My question is does one need to remove the hard oil lines from the cooler to replace the o-rings, or is it possible to leave the lines attached and move the cooler out enough to get to the o-rings? I would like to avoid removing the lines if possible to avoid destroying the oil cooler threads. I also do not have the large spanners for the oil lines. Anybody care to loan me a set of oil line wrenches (when I get the answer I think I'm going to get)? Waiting for a warm weekend to do my first partial drop, Ludwig
Chris 1985 Carrera Coupe (sold) 2004 V70R |
The 3 oil cooler o-rings are for the engine mounted oil cooler, not the fender mounted one. There are no hard lines attached to the engine cooler - it gets oil directly from the engine itself. It does have a pass-through tube at the bottom to allow oil from the tank to get into the engine, but this is not a pressurized line so only attached with a hose clamp. Technically that line does not supply oil to the cooler, but rather directly to the engine.
For the fender mounted cooler, there are no o-rings to replace.
Sounds like I need to peruse my shop manual a bit before I start asking too many questions. Yes the engine mounted cooler.
Is the engine out of the car yet?
I am waiting for a decent weather window so I can do this in my driveway. Planning partial engine drop. Should take 4 hours. Planning on at least 16 hours.
I'll try to take some photos. Maybe do some sound recording as well. I might be able to use them to prove "temporary insanity" in court after I burn the neighborhood down in a fit of rage. That or send it to a linguist to identify a new strain of terets.
I was planning on cleaning the top of the engine while I was in there. I have a can of gunk I was thinking of using, but I am worried it may be too harsh for the block/intake/etc. Any thoughts?
I was planning on doing the clean prior to the work, but then I thought about working in a big, wet greasy mess and now I think I will clean it AFTER the work is complete, but before raising the engine. Not ideal, in my opinion, but better than working in the greasy puddle.
Chris 85 Targa Custom Exhaust, Cat By-Pass & S. Wong Chip Past '77 Targa x2 |
Chris - Ludwig:
Search for the CIS removal oil leak thread I posted on here with pics (partial drop - changed all gaskets etc... you mentioned). Part of the reason I did it was to remove on-engine oil cooler and replace 3 o-rings. I had an oil leak coming from cooler down onto crossover pipe. Finished it up to discover that it was my oil cooler that has failed. Created a cheap scap metal deflector shield so that drops hit shield and and then the ground until I could get a repro or known-good-used Behr OEM cooler. Repro never showed (perf products) after several months. Just received known-good-used Behr cooler and will be re-doing partial drop to get er dun. You don't have to drop motor/tranny completely to do this. edit - thread here |
Thanks. Just what I needed something else to do. The wife and kids are going to visit freinds next weekend in NC, now I know what I'm doing.
