Damn you Tony...and your 944 Postulate! - Dorkiphus.net
Navigation » Dorkiphus.net > Miscellaneous Discussions > Miscellaneous Discussions » Damn you Tony...and your 944 Postulate!
Old 10-13-2008, 06:24 PM
dweymer's Avatar
dweymer dweymer is offline
O ya!
dweymer has one HoF thread
Default Damn you Tony...and your 944 Postulate!
2 Events in a row, I am the non running car.:XX
Donnie
1974 911-sold
1995 BMW M3-GTS2
2001 Excursion diesel tow beast
Old 10-13-2008, 06:43 PM
Alrighty then.....does this make you feel any better?
Old 10-13-2008, 06:55 PM
FTS's Avatar
FTS FTS is offline
Learning to Drive Again
FTS
How in the world can a chain do that?
Cheers,
Fatih
Old 10-13-2008, 06:58 PM
dweymer's Avatar
O ya!
is that your S2???
Not really though, at least that problem is easily diagnosed..
Donnie
1974 911-sold
1995 BMW M3-GTS2
Old 10-13-2008, 07:00 PM
hoophead's Avatar
hoophead hoophead is offline
hoophead
You really need to do something about the peeling paint on that valve cover...
Jeff S
'14 991.1 Carrera S Coupe
'25 Cayenne E-Hybrid
'11 997.2 Carrera S Cab
'09 987.2 Cayman S
'05.5 Audi S4
'25 GMC Yukon XL
'17 718 Boxster
'18 718 Cayman x 2
Old 10-13-2008, 07:02 PM
Zoiks!!!! Sorry to see. Call me when you start fixing that, since I need to replace the pads or whatever on mine this winter.
Old 10-13-2008, 07:09 PM
Rick V Rick V is offline
My wheels are blingie
Rick V
Steve pads are a piece of cake, Tony on the other hand..........................really does need to address that peeling paint issue.
82SC, Lanna
97 Boxter, She named it Willy
Go Army
Old 10-13-2008, 07:27 PM
I've done a "little" reading on it...I'm sure I can handle it. I'd call you to assist but by then you'd be certifiable...uh, certified and probably have signed the non-compete.
Old 10-13-2008, 07:43 PM
Rick V
Yeah I already had that discussion, my customers prior to going to work there are still mine I just won't pick any new ones. I may be dumb but I aints stupid.
82SC, Lanna
Go Army
Old 10-13-2008, 07:51 PM
Not 100% sure what caused it yet, but guessing the cheap plastic shim gave up the ghost. It happened last week while trying to start the car in the garage. Turned over with a strange lope.....guessing some valves are also bent, and probably more.
Trailered it to the shop this morning. They still have the motor from my 1st 944S2 which was wrecked several years ago. We're having that head pressure tested to see if its ok (that motor had oil into the water leak, suspected to be porous block issue). If that head checks out, we should be able to simply swap, after updating a few key parts.
This has been a tough couple of months for our fo-fo's.....
