Which Koni Shock inserts? - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Which Koni Shock inserts?
Old 04-26-2008, 11:00 PM
Fritz's Avatar
Fritz Fritz is offline
Addict
Fritz has one HoF thread
Default Which Koni Shock inserts?
I've been acquiring the pieces to upgrade the front brakes and suspension on my 911T (sorta) and am trying to research the strut insert options. The 3.5 inch struts assemblies have "911.341.080.10 and Heavy-turn sens-regulage 43 72" stamped on them. I haven't found a resource that matches those to the inserts that will fit. I'm looking for the adjustable sport inserts as this is going to be mainly DE so ride comfort around town isn't an issue. Any suggestions?
I've got the rest of the pieces all picked out on Pelican. I've got the Rennline monoballs, brake rebuild kits, new rotors, and pads in my checkout cart. I was also going to grab some caliper paint. Does painting have any negative effects?
I'm trying to keep the dollars down, but if there is something I should be throwing in at this point while I'm at it? I'd rather do it now than have to undo and realign again(unless it breaks the piggy bank).
Old 04-27-2008, 09:39 AM
I think you are over thinking this. Just call Koni or http://www.koni-na.com/cat_search_form.cfm
Shopping is your friend to entend your $$$
Old 04-27-2008, 04:58 PM
Fritz's Avatar
Addict
I'm good at over thinking things.. I don't want to just assume that all Koni strut assemblies are the same through out the years. I'll give them a call tomorrow and get everything ordered.
