Trying to see what parts I will need for the swap on pelican the same clutch and pressure plate are listed for 72-86 911's. That would mean that I can use the cluthc and pressure plate off my 3.0 in the 3.2 correct? My clutch probably only has about 20K mies on them so I should be able to reuse them right? I did find where the flywheel is different. And finally I thought I was told you are supposed to replace the pressure plate and flywheel bolts whenever the pressure plate or clutch was removed, is that correct?
I'll talk to you about it tomorrow.
Don't forget the ring for the pckups boy-o
The 3.2 still has the flywheel with it. Just need to notch the trans for the crank sensor
Yep the flywheel w/ pickups is still on the engine. Yes you can reuse the clutch that was mounted on your 3.0 flywheel with the 3.2 flywheel.
Kaefer |
