Results of too much boost - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Porsche Technical Discussions » Results of too much boost
Old 08-20-2007, 08:29 PM
Geoff Daniels Geoff Daniels is offline
Geoff Daniels
Default Results of too much boost
Completed the autopsy this evening on my 951 that was so nicley caught on film by Harlequin during it's last moment of life.
The good news is that it was just the head gasket and everything else looks really good. I have a picture shows what >20 lbs of boost can do to a 20 year old head gasket but it is bigger then the website will allow me to post. Any tricks for paotins pictures
New parts are on their way and with any luck it should be DE ready by Sunday.
Geoff
86 951, 96 993 C2
Old 08-20-2007, 08:50 PM
Geoff
Dial back the boost, try a 20 minute run... just once
Old 08-20-2007, 09:36 PM
Alan Herod Alan Herod is offline
Alan Herod
I observed that Geoff had the boost dialed way back, perhaps to less then stock levels; but, he failed to relay that the over boost was caused by failure of the overboost control (melted hose).
Alan
83 SC (trackster)
90 C2 (Sally's Carrera)
13 Audi S4
04 Avalanche Blingmobile
08 BMW 135I
----- ones that got away -------------------
57 Speedster 1500GS the one that got away
02 Boxster S (Partster S - recent modification)
Old 08-20-2007, 09:43 PM
No he said that during lunch, just couldn't resist!
Old 08-21-2007, 07:51 PM
Geoff Daniels
Smile
Your a tough man DR. One day I will get more then a few 20 minute runs in and get promoted to White. Then I will turn up the boost and see if I can with you.
86 951, 96 993 C2
Old 08-21-2007, 08:08 PM
I was soooo wrong! Keep the boost on full now... don't miss a chance to have fun in blue... white is overrated and I already have hunt and scott to deal with
Old 08-22-2007, 12:34 AM
APKhaos's Avatar
APKhaos APKhaos is offline
APKhaos
Hey Geoff,
A head gasket every now and then is worth it, right?
I had a cycling valve fail, so rigged a very simple bleed on the wastegate control line to keep running for the weekend. It was fairly peaky, but when it peaked to 20# the car just leapt up the track. Its addictive. Guess I might have had a bit too much fun with it. I installed a new cycling valve for our VIR race, but too much time at 20# took its toll. The head gasket blew on the cool down lap AFTER the checker.
Head gaskets are dead easy in our cars after you've done a couple.
Tony K
PCA Potomac, Rennlist Member
89 944 Turbo
85 Carrera - Sold
TrackVision
944Cup
Old 08-22-2007, 08:10 AM
Then they're the only thing that is... well except for breaking
Old 08-22-2007, 08:20 AM
Alan Herod
Tony, did you do head studs every time you changed head gasket or did you install raceware the first time and never change them again?
What is the recommended technique for removing head studs?
Alan
83 SC (trackster)
13 Audi S4
08 BMW 135I
Old 08-22-2007, 03:27 PM
Geoff Daniels
Tony, you are absolutely correct, a head gasket is a pretty easy fix. I could have had mine fixed in less then 4 hours if I had the parts sitting on my bench. This motor was a unmolested 20 year old motor so when the head came off I had some major corrosion on the top stud by the #1 cylinder. I am replacing the studs with raceware studs. Getting the old studs out is the only hard part of the repair.
I have deleted the CV valve and have a manual boost controller which was set at a conservative 13 lbs. When the vacuum line to the waste gate failed the turbo went to full boost which I am guessing was in the neighborhood of 25 + lbs of boost. It is a larger then stock turbo. It pulled like a banshee until the head gasket had enough, this only took a few seconds.
With raceware studs and a widefire gasket I may have to crank the boost up to about 16 lbs. Then I should be ready for DR, at least I can humiliate him on the straights.
86 951, 96 993 C2
