Broken oil line stud - Dorkiphus.net
Old 04-09-2007, 10:41 AM
kimlangley7's Avatar
kimlangley7 kimlangley7 is offline
kimlangley7
Default Broken oil line stud
Continued work this weekend of install of my SSIs and M&K on my 80 SC.
In the process > I broke off the stud [aft of the thermostat] that holds the oil lines close to the car body.
Is this stud screwed into the body? or welded?
I've got about 1/4 inch remaining
anyone BTDT ? suggestions??
kgl
Kim Langley
1980 911SC [Euro spec]
1997 Mercedes C230
1973 BMW 2002Tii
1999 BMW M3 [son- Nick]
2008 Kawasaki Ninja 650 [son-Ryan]
Old 04-09-2007, 02:17 PM
I do believe those are welded.
If you dont have access to the backside to just drill it out and use a bolt/nut, think about using a "nutsert" or welding on another stud. FWIW, a nutsert is a threaded rivet. Allows one to essentially pop-rivet a nut onto any sheet metal. Works great for things like this. I think I have M4 and/or M6s around to give you one if you want to try that route.
SMD
1984 930 - 3.6L
Old 04-09-2007, 02:25 PM
Excellent nutsert animation here.
Old 04-09-2007, 03:24 PM
kimlangley7
Nutsert >> very cool
thanks for the link..
Kim Langley
1997 Mercedes C230
1973 BMW 2002Tii
