So far I've been able to remove 4 barrel nuts safely, and one come off flush with the stud (some fun ahead
Any thoughts?
My thought is you should have had heat BEFORE you mangled those nuts. Of course, I have better hindsight than foresight...
You can borrow my propane torch, but of course for the $15 you should just drive to Home Despot and but one. Peter
While you are at Home Depot, swing by Sears and buy yourself a set of outside extractors. Best thing since sliced white bread
OUtside extractors? BTW, for some reason te only heat I've had success with is oxy/aceteline.
These kids. I bought this cheepo set at lowes, just to get me out of a bind one day.
never enough money...never enough time...nothing ever fits 82SC, Lanna 02 C240, Das-Uber-Lux-O-Cruiser 97 Boxter, She named it Willy 86 Dodge 4X4, Peggy, The Arctic Warrior Go Army Last edited by Rick V; 06-13-2007 at 08:02 PM. |
Thanks Rick. Going tools shopping. (also will have to go to Bath and Body with Becky to keep the harmony)
You need one of these (assuming the nuts are 13mm):
Jeff S '14 991.1 Carrera S Coupe '25 Cayenne E-Hybrid '11 997.2 Carrera S Cab '09 987.2 Cayman S '05.5 Audi S4 '25 GMC Yukon XL '17 718 Boxster '18 718 Cayman x 2 |
And one of these:
Or not... (Why is he smiling?)
Peter, you scare me.
Mauled nuts in a tight place? sounds like a job for a Dremmel grinder with a one inch cut-of wheel. Or realistically, about half a dozen to ten wheels--you'll no doubt break several, but make a good deep cut--but not so deep as to badly scar the shaft of the stud, then a flat screw driver or cold chisel into the gap, a few taps to spread it, maybe another hit of the liquid penetrant, too. Either it will split, or unscrew. Done it lots of times, almost always on exhaust nuts.
