how do i do that on my car? are there retaining clips/pins, or just screws that have to be reached from the inside?
if screws, once UN-screwed, does the handle just come off or is there another hidden procedure for freeing them from the body? thank you. |
Hi Dave,
Yes, just the two nuts. If you have power locks then just undo the wire. Andy
Andy 11 Cayenne S White/Tan SUV 91 964 C2 Black/Black Cabriolet 72 911T Black/Black Coupe 73 911E Bahia Red/Black 66 911 POS Tribute (Yes, but its MY ugly) |
Oh My bad Dave,
I assumed you were talking about the outer door handles?. If inner door handles, I believe there are four bolts and two screws. Four allen bolts that holds the inner door handles to the door, one screw that holds the door panel to the door handle, and one screw that holds the door pocket to the handle. Andy
thanks guys. yes andy, i meant the outer...
another Q: if i'm going to have the locks re-keyed, do i need to remove the cylinders or can i just give them in one piece to the locksmith? ie: will i screw things up if i remove the locks myself? |
Take the entire handle to the locksmith. They are well smart enough to remove replace the cyl from the handle and will thank you for doing so as they can test the pin work.
thanks kurt... just from reading up on this i figured i'm going to have tons of little springs and pins shooting out from the thing...
since i'm farming this out, "it's easy enough" that sure looks like a crap task... need some infant w/ small hands to reach in there.. |
