Fofo IAC - Dorkiphus.net
Old 08-25-2019, 06:58 PM
Le Cochon Volant's Avatar
Le Cochon Volant Le Cochon Volant is offline
Le Cochon Volant
Default Fofo IAC
Having just completed a bunch of work on our 951, when we started it the cold idle was fine but when it warms up the idle settles around 2K. I did all the checks and discovered that if I plug the IAC valve it idles just fine warm. I'm guessing it has gotten lazy, gummed up or something else. I did look at it when the intake manifold was off but decided to leave it alone since it hadn't given any trouble before. I'm not really anxious to pull the intake back off to replace it if I don't truly need to. If its running fine can I leave it alone? Anyone else have any experience with this?
Thanks
Holder
1969 911S
1999 996 C2 Coupe (The Flying Pig)
2016 GT3 Cup
2015 GT3
1988 951
1989 944 S2
2002 Boxster S (project)
1972 914 1.7
2013 Cayenne Diesel (wifey's DD)
2007 E350 4matic wagon DD
2008 Chevy 3500 dually tow truck
Old 08-25-2019, 10:37 PM
Richard Curtis's Avatar
Richard Curtis
clean the IAC valve. Easy to do.
Richard Curtis
Old 08-25-2019, 11:04 PM
TurboPooch's Avatar
Now known as Robbie's dad
TurboPooch
When plugged in if you hear it fluttering at idle its probably wacked. Just unplug and realize if there is increased drag on the engine (A/C turned on, increased current draw on the alternator, power steering while not moving, etc) it might fall below normal idle and possibly stall. Easy to fix with the foot or just bump up the idle a few rpm to compensate.
Steve Potomac PCA Co-CI
89 944 Turbo - 2010 944 SuperCup Mid-Atlantic Champ, 2013 944 SuperCup North Chapter Champ
85.5 944 NA son's 2015/2019 944Cup and PCA Nat'l Champ racecar
98 993 C2S w/Aerokit II
77 911S project
70 Boss 302
86 Mustang SVO
08 F250 SD Diesel
15 Audi SQ5
