stock 981 track alignment settings? - Dorkiphus.net
Navigation » Dorkiphus.net > Technical & Track Disussions > Track Talk » stock 981 track alignment settings?
Old 07-06-2019, 07:47 AM
Otto's Avatar
Otto Otto is offline
Otto
Default stock 981 track alignment settings?
i wanted to get a 'track' alignment on my stock 981 this week
i don't know what is possible, but thought i would ask here
i was thinking max neg camber, 1 degree toe out on front, 1 degree toe in on the rear
if you have a 981 and can comment, please do so, message me if you like
thanks
otto
Otto
#906
2014 Cayman S
2012 Cayman S - retired
2006 Boxster S
Old 07-06-2019, 08:47 AM
Call Charlie at Intersport for the 411 on this. I doubt if most owners even know their alignments just be sure to explain what you want I.e. street/ de, de/street etc.
Old 07-06-2019, 08:51 AM
trytryagain's Avatar
trytryagain
Max out the negative camber maintaining equal left and right and see what you get. It is somewhat chassis dependent. Probably will be less than 2 degrees. I added front camber plates which gave closer to 2.5. More than this will need a control arm upgrade. My front toe is 0.0. Rear is 0.15.
Tire wear has been notably improved with the increased camber.
Jim C.
1986 911 Targa (Aka "Dusty")
1971 914 (back in the day)
Old 07-07-2019, 12:16 AM
Otto's Avatar
Otto
what caber plates did you use?
Otto
#906
2014 Cayman S
2006 Boxster S
Old 07-07-2019, 12:40 AM
Otto's Avatar
Otto
what camber plates did you use?
Otto
#906
2014 Cayman S
2006 Boxster S
Old 07-07-2019, 02:58 AM
I guess I’m unclear on your definition of “stock”
Old 07-07-2019, 06:30 AM
trytryagain
Here’s what I have:
https://www.tarett.com/items/986-987...8#ITEM_7054732
Jim C.
Old 07-07-2019, 04:01 PM
Dandelion's Avatar
Dandelion
2016 GT4
2012 Cayman R
2005 Lotus Elise
1994 RX-7 R2
Old 07-09-2019, 03:26 PM
Otto's Avatar
Otto
well it has PASM from the factory
it does not have gt3 lca or anything of that sort, so extreme negative camber is not going to be possible
Otto
#906
2014 Cayman S
2006 Boxster S
Old 07-09-2019, 03:28 PM
Otto's Avatar
Otto
not clear to me which is better way to get more camber
replace the lower control arms
add camber plates
Otto
#906
2014 Cayman S
2006 Boxster S
